Hi All,
want to share example apps to control the Master Brick and Bricklets using B4x (see http://www.b4x.com - Rapid Application Development (RAD) tools for native Android (B4A), iOS (B4i) and desktop / webserver apps (B4J)). So far, have not seen any TinkerForge examples using B4x. With B4x it is rather simple to control Bricks using the Java Library. It is also possible to use the JavaScript Library.
Additional information & examples
Control Bricklets RemoteSwitch, Temperature, Humidity
B4A & B4J App using TinkerForge Java API Binding.
http://www.b4x.com/android/forum/threads/tinkerforge-control-example.48625/#post-302383
Raspberry Pi Webserver to control Bricklet RemoteSwitch
B4J Webserver using JQuery Mobile & TinkerForge JavaScript API Binding.
http://www.b4x.com/android/forum/threads/home-automation-with-b4a-b4j-using-tinkerforge.41474/#post-252946
More apps under Development.
Enjoy,
Rob
Not sure if i completely understand what is happening :D.
You can use some kind of Basic dialect to write Apps for Android/iOS with b4x and you talk to the Bricks/Bricklets through this Basic with the help of our Java Bindings.
Right?
Hi borg,
Yes that is correct.
Anywhere Software offers Rapid Application Development tools for native Android (tool B4A), iOS (tool B4i) and Desktop plus server (tool B4J). I have developed first B4A and B4J apps to talk to a TinkerForge MasterBrick and several connected Bricklets (RemoteSwitch, Temperature, Humidity, Barometer) using the tinkerforge.jar Library. The Basic dialect developed by Anywhere Software offers a JavaObject library to make that happen.
