Dragony Geschrieben December 24, 2014 at 15:35 Geschrieben December 24, 2014 at 15:35 Hallo ich habe heute endlich den RED bekommen und natürlich direkt ausprobiert. Leider dauert die Bootzeit verdächtig lange und nach einem Ausflug ins dmesg stehen da einige Timeouts und verdächtig lang dauernde Routinen, die eigentlich schneller ablaufen sollten. Sind die 115 Sekunden Bootzeit normal? Es handelt sich um Fast Image 1.1. root@red-brick:~# dmesg (Wegen 20kb Postlimit gekürzt: Anzeige ab 0.25s) [ 0.250486] I2C: i2c-3: HDMI I2C adapter [ 0.263207] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 0.263252] [mmc-msg] sdc0 set round clock 400000, src 24000000 [ 0.335553] [mmc-err] smc 0 err, cmd 52, RTO [ 0.336385] [mmc-err] smc 0 err, cmd 52, RTO [ 0.336406] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 0.338782] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 0.340917] [mmc-err] smc 0 err, cmd 5, RTO [ 0.341740] [mmc-err] smc 0 err, cmd 5, RTO [ 0.342562] [mmc-err] smc 0 err, cmd 5, RTO [ 0.343385] [mmc-err] smc 0 err, cmd 5, RTO [ 0.344024] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 0.344041] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 0.346413] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B [ 0.417112] [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B [ 0.417129] [mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 1 timing SD-HS(SDR25) dt B [ 0.417171] [mmc-msg] sdc0 set round clock 42857142, src 300000000 [ 0.472235] [mmc-msg] sdc0 set ios: clk 50000000Hz bm PP pm ON vdd 3.3V width 4 timing SD-HS(SDR25) dt B [ 0.472257] mmc0: new high speed SDHC card at address aaaa [ 0.472556] mmcblk0: mmc0:aaaa SL08G 7.40 GiB [ 0.473849] mmcblk0: p1 [ 5.273147] [ 5.273153] [ 5.273157] insmod_device_driver [ 5.273161] [ 5.273169] [sw_udc]: sw_usb_device_enable start [ 5.273179] [sw_udc]: usb_vbase = 0xf1c13000 [ 5.273189] [sw_udc]: sram_vbase = 0xf1c00000 [ 5.273212] [sw_udc]: open_usb_clock [ 5.293224] [sw_udc]: CONFIG_USB_GADGET_DUALSPEED [ 5.293237] udc->driver is null, udc is need not start [ 5.293244] [sw_udc]: sw_usb_device_enable end [ 10.273103] Timeout waiting for EDID info [ 10.273154] disp clks: lcd 74250000 pre_scale 1 hdmi 74250000 pll 297000000 2x 0 [ 10.941410] Console: switching to colour frame buffer device 160x45 [ 10.954921] ALSA device list: [ 10.954931] No soundcards found. [ 10.961480] EXT3-fs (mmcblk0p1): mounted filesystem with ordered data mode [ 10.961537] VFS: Mounted root (ext3 filesystem) readonly on device 179:1. [ 10.961642] kjournald starting. Commit interval 5 seconds [ 10.962866] devtmpfs: mounted [ 10.963135] Freeing init memory: 132K [ 11.983930] udevd[162]: starting version 175 [ 15.897188] EXT3-fs (mmcblk0p1): using internal journal [ 16.330288] [sw_udc]: [sw_usb_udc]: binding gadget driver 'RED Brick' [ 16.330322] [sw_udc]: alloc request: ep(0x8074b828, ep0, 64), req(0x9ec88040) [ 16.332311] ep_matches, wrn: endpoint already claimed, ep(0x8074b874, 0x9fb8f700, ep1-bulk) [ 16.332331] [sw_udc]: alloc request: ep(0x8074b874, ep1-bulk, 512), req(0x9ec88540) [ 16.332347] [sw_udc]: alloc request: ep(0x8074b874, ep1-bulk, 512), req(0x9ec88600) [ 16.332362] [sw_udc]: alloc request: ep(0x8074b874, ep1-bulk, 512), req(0x9ec88640) [ 16.332374] [sw_udc]: alloc request: ep(0x8074b874, ep1-bulk, 512), req(0x9ec88680) [ 16.332387] [sw_udc]: alloc request: ep(0x8074b874, ep1-bulk, 512), req(0x9ec886c0) [ 16.332399] [sw_udc]: alloc request: ep(0x8074b874, ep1-bulk, 512), req(0x9ec88700) [ 16.332412] [sw_udc]: alloc request: ep(0x8074b874, ep1-bulk, 512), req(0x9ec88740) [ 16.332424] [sw_udc]: alloc request: ep(0x8074b874, ep1-bulk, 512), req(0x9ec88780) [ 16.332437] [sw_udc]: alloc request: ep(0x8074b874, ep1-bulk, 512), req(0x9ec887c0) [ 16.332450] [sw_udc]: alloc request: ep(0x8074b874, ep1-bulk, 512), req(0x9ec88800) [ 16.332462] [sw_udc]: alloc request: ep(0x8074b874, ep1-bulk, 512), req(0x9ec88840) [ 16.332474] [sw_udc]: alloc request: ep(0x8074b8c0, ep2-bulk, 512), req(0x9ec88880) [ 16.332487] [sw_udc]: alloc request: ep(0x8074b8c0, ep2-bulk, 512), req(0x9ec888c0) [ 16.332500] [sw_udc]: alloc request: ep(0x8074b8c0, ep2-bulk, 512), req(0x9ec88900) [ 16.332512] [sw_udc]: alloc request: ep(0x8074b8c0, ep2-bulk, 512), req(0x9ec88940) [ 16.332524] [sw_udc]: alloc request: ep(0x8074b8c0, ep2-bulk, 512), req(0x9ec88980) [ 16.332537] [sw_udc]: alloc request: ep(0x8074b8c0, ep2-bulk, 512), req(0x9ec889c0) [ 16.332550] [sw_udc]: alloc request: ep(0x8074b8c0, ep2-bulk, 512), req(0x9ec88a00) [ 16.332563] [sw_udc]: alloc request: ep(0x8074b8c0, ep2-bulk, 512), req(0x9ec88a40) [ 16.332575] [sw_udc]: alloc request: ep(0x8074b8c0, ep2-bulk, 512), req(0x9ec88a80) [ 16.332587] [sw_udc]: alloc request: ep(0x8074b8c0, ep2-bulk, 512), req(0x9ec88ac0) [ 16.332602] PPPHHH: dual speed brick: IN/ep1-bulk, OUT/ep2-bulk [ 16.332616] ep_matches, wrn: endpoint already claimed, ep(0x8074b874, 0x9fb8f700, ep1-bulk) [ 16.332627] ep_matches, wrn: endpoint already claimed, ep(0x8074b8c0, 0x9fb8f700, ep2-bulk) [ 16.332639] ep_matches, wrn: endpoint already claimed, ep(0x8074b874, 0x9fb8f700, ep1-bulk) [ 16.332650] ep_matches, wrn: endpoint already claimed, ep(0x8074b8c0, 0x9fb8f700, ep2-bulk) [ 16.332661] ep_matches, wrn: endpoint already claimed, ep(0x8074b90c, 0x9ec88000, ep3-bulk) [ 16.332673] ep_matches, wrn: endpoint already claimed, ep(0x8074b874, 0x9fb8f700, ep1-bulk) [ 16.332684] ep_matches, wrn: endpoint already claimed, ep(0x8074b8c0, 0x9fb8f700, ep2-bulk) [ 16.332695] ep_matches, wrn: endpoint already claimed, ep(0x8074b90c, 0x9ec88000, ep3-bulk) [ 16.332706] ep_matches, wrn: endpoint already claimed, ep(0x8074b958, 0x9ec88000, ep4-bulk) [ 16.332715] [sw_udc]: alloc request: ep(0x8074b9a4, ep5-int, 512), req(0x9ec88b00) [ 16.332753] RED Brick gadget: RED Brick ready [ 16.332762] [sw_udc]: CONFIG_USB_GADGET_DUALSPEED [ 16.332774] [sw_udc]: usbd_start_work [ 16.388238] [sw_udc]: IRQ: suspend [ 16.388263] [sw_udc]: ERR: usb speed is unkown [ 16.614605] [sw_udc]: IRQ: reset [ 16.614630] [sw_udc]: irq: reset happen, throw away all urb [ 16.683122] [sw_udc]: [ 16.683142] +++++++++++++++++++++++++++++++++++++ [ 16.683150] [sw_udc]: usb enter high speed. [ 16.683158] [sw_udc]: [ 16.683163] +++++++++++++++++++++++++++++++++++++ [ 16.688626] [sw_udc]: IRQ: reset [ 16.688652] [sw_udc]: irq: reset happen, throw away all urb [ 16.755109] [sw_udc]: Set address 124 [ 16.776018] RED Brick gadget: high-speed config #1: foobar [ 16.776038] [sw_udc]: ep enable: ep1(0x8074b874, ep1-bulk, 128, 512) [ 16.776061] [sw_udc]: ep enable: ep2(0x8074b8c0, ep2-bulk, 0, 512) [ 16.776087] [sw_udc]: ep enable: ep5(0x8074b9a4, ep5-int, 128, 10) [ 16.776103] [sw_udc]: ep enable: ep3(0x8074b90c, ep3-bulk, 128, 512) [ 16.776116] [sw_udc]: ep enable: ep4(0x8074b958, ep4-bulk, 0, 512) [ 16.776356] nuke: ep num is 0 [ 16.776633] WRN:L1355(drivers/usb/sunxi_usb/udc/sw_udc.c):handle_ep0: ep0 setup end [ 16.776646] nuke: ep num is 0 [ 86.413742] [sw_udc]: alloc request: ep(0x8074b958, ep4-bulk, 512), req(0x9ec8fdc0) [ 86.413772] [sw_udc]: alloc request: ep(0x8074b958, ep4-bulk, 512), req(0x9ec8fa80) [ 86.413785] [sw_udc]: alloc request: ep(0x8074b958, ep4-bulk, 512), req(0x9ec8fb00) [ 86.413800] [sw_udc]: alloc request: ep(0x8074b958, ep4-bulk, 512), req(0x9ec8fac0) [ 86.413814] [sw_udc]: alloc request: ep(0x8074b958, ep4-bulk, 512), req(0x9ec8fb40) [ 86.413827] [sw_udc]: alloc request: ep(0x8074b958, ep4-bulk, 512), req(0x9ec8fcc0) [ 86.413840] [sw_udc]: alloc request: ep(0x8074b958, ep4-bulk, 512), req(0x9fa7d100) [ 86.413853] [sw_udc]: alloc request: ep(0x8074b958, ep4-bulk, 512), req(0x9fa7d600) [ 86.413874] [sw_udc]: alloc request: ep(0x8074b958, ep4-bulk, 512), req(0x9fa7de00) [ 86.413888] [sw_udc]: alloc request: ep(0x8074b958, ep4-bulk, 512), req(0x9fa7da00) [ 86.413900] [sw_udc]: alloc request: ep(0x8074b958, ep4-bulk, 512), req(0x9fa7d400) [ 86.413913] [sw_udc]: alloc request: ep(0x8074b958, ep4-bulk, 512), req(0x9fa7dc80) [ 86.413926] [sw_udc]: alloc request: ep(0x8074b958, ep4-bulk, 512), req(0x9f84fdc0) [ 86.413939] [sw_udc]: alloc request: ep(0x8074b958, ep4-bulk, 512), req(0x9ec88bc0) [ 86.413952] [sw_udc]: alloc request: ep(0x8074b958, ep4-bulk, 512), req(0x9ec88ec0) [ 86.413964] [sw_udc]: alloc request: ep(0x8074b958, ep4-bulk, 512), req(0x9ec88d00) [ 86.413979] [sw_udc]: alloc request: ep(0x8074b90c, ep3-bulk, 512), req(0x9ec88d40) [ 86.413992] [sw_udc]: alloc request: ep(0x8074b90c, ep3-bulk, 512), req(0x9ec88e40) [ 86.414005] [sw_udc]: alloc request: ep(0x8074b90c, ep3-bulk, 512), req(0x9ec88c40) [ 86.414017] [sw_udc]: alloc request: ep(0x8074b90c, ep3-bulk, 512), req(0x9ec88dc0) [ 86.414030] [sw_udc]: alloc request: ep(0x8074b90c, ep3-bulk, 512), req(0x9ec88f40) [ 86.414042] [sw_udc]: alloc request: ep(0x8074b90c, ep3-bulk, 512), req(0x9ec88d80) [ 86.414054] [sw_udc]: alloc request: ep(0x8074b90c, ep3-bulk, 512), req(0x9ec88fc0) [ 86.414067] [sw_udc]: alloc request: ep(0x8074b90c, ep3-bulk, 512), req(0x9ec88cc0) [ 86.414081] [sw_udc]: alloc request: ep(0x8074b90c, ep3-bulk, 512), req(0x9ec88f80) [ 86.414095] [sw_udc]: alloc request: ep(0x8074b90c, ep3-bulk, 512), req(0x9ec88f00) [ 86.414107] [sw_udc]: alloc request: ep(0x8074b90c, ep3-bulk, 512), req(0x9ec88c80) [ 86.414120] [sw_udc]: alloc request: ep(0x8074b90c, ep3-bulk, 512), req(0x9ee75c80) [ 86.414133] [sw_udc]: alloc request: ep(0x8074b90c, ep3-bulk, 512), req(0x9ee75f00) [ 86.414145] [sw_udc]: alloc request: ep(0x8074b90c, ep3-bulk, 512), req(0x9ee75240) [ 86.414158] [sw_udc]: alloc request: ep(0x8074b90c, ep3-bulk, 512), req(0x9ee75140) [ 86.414170] [sw_udc]: alloc request: ep(0x8074b90c, ep3-bulk, 512), req(0x9ee75780) [ 87.790030] incomplete xfer (0x20) [ 87.799514] w5x00: 2.0.0 [ 87.799587] w5x00 probe [int 17, rst 15, sel 0, mac 40:d8:55:2:a3:5b] [ 87.799597] chip select before: 0 [ 89.551668] Version test w5500 : 00 [ 91.050730] Version test w5200 : 03 [ 91.050743] Found W5200 [ 92.575906] Version : 03 [ 92.575965] iinchip_socket_sethwaddr():671=40:d8:55:2:a3:5b [ 92.576064] w5x00: MAC [40:d8:55:02:a3:5b] [ 92.576144] w5x00: socket(0) Tx(0x4000,0x3fff,0x8000) Rx(0x4000,0x3fff,0xc000) [ 92.576220] w5x00: socket(1) Tx(0x0,0x0,0x8000) Rx(0x0,0x0,0xc000) [ 92.576296] w5x00: socket(2) Tx(0x0,0x0,0x8000) Rx(0x0,0x0,0xc000) [ 92.576371] w5x00: socket(3) Tx(0x0,0x0,0x8000) Rx(0x0,0x0,0xc000) [ 92.576445] w5x00: socket(4) Tx(0x0,0x0,0x8000) Rx(0x0,0x0,0xc000) [ 92.576520] w5x00: socket(5) Tx(0x0,0x0,0x8000) Rx(0x0,0x0,0xc000) [ 92.576595] w5x00: socket(6) Tx(0x0,0x0,0x8000) Rx(0x0,0x0,0xc000) [ 92.576670] w5x00: socket(7) Tx(0x0,0x0,0x8000) Rx(0x0,0x0,0xc000) [ 92.586130] w5x00 spi register succeed [ 115.764548] WRN:L1355(drivers/usb/sunxi_usb/udc/sw_udc.c):handle_ep0: ep0 setup end [ 115.764570] nuke: ep num is 0 Zitieren
borg Geschrieben December 24, 2014 at 16:14 Geschrieben December 24, 2014 at 16:14 Benutzt du eine unserer SD Karten oder eine eigene? Falls es eine eigene ist, welche Klasse hat sie? (class 4, class 10, UHS-1, ...) Das Fast Image mit einer 45MB/s SD Karte bootet aktuell in ca. 35 Sekunden. Mehr Informationen dazu gibt es hier: http://www.tinkerunity.org/forum/index.php/topic,2709.msg17374.html Bootchart: http://i.imgur.com/sIxhuwY.png Die [mmc-err] smc 0 err, cmd 52, RTO und [mmc-msg] sdc0 set ios: clk 400000Hz bm PP pm ON vdd 3.3V width 1 timing LEGACY(SDR12) dt B Meldungen sind normal. Ich zitiere mal dazu mal von der offiziellen linux-sunxi Mailinglist: These errors are caused by the linux mmc subsystem making calls which only work on sdio devices (ie sdio wifi cards) which fail on sd-cards. This is only done during initial probing of the card when the mmc subsys tries to find out what kind of card is exactly connected. They can safely be ignored. Zitieren
Dragony Geschrieben December 24, 2014 at 16:16 Autor Geschrieben December 24, 2014 at 16:16 Hallo borg, es ist die Originalkarte von euch, nur neu geflasht mit dem 1.1er Image, da noch das 1.0er drauf war. Hört das dmesg einer schnell bootenden Karte auch erst bei 115s auf? Zitieren
borg Geschrieben December 24, 2014 at 16:37 Geschrieben December 24, 2014 at 16:37 Anbei das dmesg einer frischen fast Image SD Karte auf einem RED Brick mit einem Master Brick und zwei Bricklets: ... [ 5.293412] [sw_udc]: sw_usb_device_enable end [ 14.209346] kjournald starting. Commit interval 5 seconds [ 14.219925] EXT3-fs (mmcblk0p1): recovery complete [ 14.219938] EXT3-fs (mmcblk0p1): mounted filesystem with ordered data mode [ 14.220003] VFS: Mounted root (ext3 filesystem) readonly on device 179:1. [ 14.221266] devtmpfs: mounted [ 14.221471] Freeing init memory: 132K [ 14.665939] bootchart continuing boot [ 16.024593] udevd[258]: starting version 175 [ 16.869012] qf9700 3-1:1.0: eth0: register 'qf9700' at usb-sw-ohci-1, QF9700 USB Ethernet, 00:e0:4c:53:44:58 [ 16.869125] usbcore: registered new interface driver qf9700 [ 19.408598] EXT3-fs (mmcblk0p1): using internal journal [ 19.921904] [sw_udc]: [sw_usb_udc]: binding gadget driver 'RED Brick' [ 19.921927] [sw_udc]: alloc request: ep(0x8074b838, ep0, 64), req(0x9d13a600) [ 19.924014] ep_matches, wrn: endpoint already claimed, ep(0x8074b884, 0x9fbcb900, ep1-bulk) [ 19.924031] [sw_udc]: alloc request: ep(0x8074b884, ep1-bulk, 512), req(0x9d13ab00) [ 19.924046] [sw_udc]: alloc request: ep(0x8074b884, ep1-bulk, 512), req(0x9d13abc0) [ 19.924059] [sw_udc]: alloc request: ep(0x8074b884, ep1-bulk, 512), req(0x9d13ac00) [ 19.924071] [sw_udc]: alloc request: ep(0x8074b884, ep1-bulk, 512), req(0x9d13ac40) [ 19.924084] [sw_udc]: alloc request: ep(0x8074b884, ep1-bulk, 512), req(0x9d13ac80) [ 19.924096] [sw_udc]: alloc request: ep(0x8074b884, ep1-bulk, 512), req(0x9d13acc0) [ 19.924108] [sw_udc]: alloc request: ep(0x8074b884, ep1-bulk, 512), req(0x9d13ad00) [ 19.924122] [sw_udc]: alloc request: ep(0x8074b884, ep1-bulk, 512), req(0x9d13ad40) [ 19.924135] [sw_udc]: alloc request: ep(0x8074b884, ep1-bulk, 512), req(0x9d13ad80) [ 19.924147] [sw_udc]: alloc request: ep(0x8074b884, ep1-bulk, 512), req(0x9d13adc0) [ 19.924159] [sw_udc]: alloc request: ep(0x8074b884, ep1-bulk, 512), req(0x9d13ae00) [ 19.924172] [sw_udc]: alloc request: ep(0x8074b8d0, ep2-bulk, 512), req(0x9d13ae40) [ 19.924185] [sw_udc]: alloc request: ep(0x8074b8d0, ep2-bulk, 512), req(0x9d13ae80) [ 19.924197] [sw_udc]: alloc request: ep(0x8074b8d0, ep2-bulk, 512), req(0x9d13aec0) [ 19.924210] [sw_udc]: alloc request: ep(0x8074b8d0, ep2-bulk, 512), req(0x9d13af00) [ 19.924222] [sw_udc]: alloc request: ep(0x8074b8d0, ep2-bulk, 512), req(0x9d13af40) [ 19.924234] [sw_udc]: alloc request: ep(0x8074b8d0, ep2-bulk, 512), req(0x9d13af80) [ 19.924246] [sw_udc]: alloc request: ep(0x8074b8d0, ep2-bulk, 512), req(0x9d13afc0) [ 19.924260] [sw_udc]: alloc request: ep(0x8074b8d0, ep2-bulk, 512), req(0x9fbedf80) [ 19.924273] [sw_udc]: alloc request: ep(0x8074b8d0, ep2-bulk, 512), req(0x9d1234c0) [ 19.924285] [sw_udc]: alloc request: ep(0x8074b8d0, ep2-bulk, 512), req(0x9d123a00) [ 19.924300] PPPHHH: dual speed brick: IN/ep1-bulk, OUT/ep2-bulk [ 19.924313] ep_matches, wrn: endpoint already claimed, ep(0x8074b884, 0x9fbcb900, ep1-bulk) [ 19.924325] ep_matches, wrn: endpoint already claimed, ep(0x8074b8d0, 0x9fbcb900, ep2-bulk) [ 19.924336] ep_matches, wrn: endpoint already claimed, ep(0x8074b884, 0x9fbcb900, ep1-bulk) [ 19.924347] ep_matches, wrn: endpoint already claimed, ep(0x8074b8d0, 0x9fbcb900, ep2-bulk) [ 19.924358] ep_matches, wrn: endpoint already claimed, ep(0x8074b91c, 0x9d13a5c0, ep3-bulk) [ 19.924370] ep_matches, wrn: endpoint already claimed, ep(0x8074b884, 0x9fbcb900, ep1-bulk) [ 19.924381] ep_matches, wrn: endpoint already claimed, ep(0x8074b8d0, 0x9fbcb900, ep2-bulk) [ 19.924392] ep_matches, wrn: endpoint already claimed, ep(0x8074b91c, 0x9d13a5c0, ep3-bulk) [ 19.924403] ep_matches, wrn: endpoint already claimed, ep(0x8074b968, 0x9d13a5c0, ep4-bulk) [ 19.924413] [sw_udc]: alloc request: ep(0x8074b9b4, ep5-int, 512), req(0x9d123500) [ 19.924448] RED Brick gadget: RED Brick ready [ 19.924456] [sw_udc]: CONFIG_USB_GADGET_DUALSPEED [ 19.924468] [sw_udc]: usbd_start_work [ 19.979929] [sw_udc]: IRQ: suspend [ 19.979947] [sw_udc]: ERR: usb speed is unkown [ 20.106209] [sw_udc]: IRQ: reset [ 20.106233] [sw_udc]: irq: reset happen, throw away all urb [ 20.216816] [sw_udc]: [ 20.216832] +++++++++++++++++++++++++++++++++++++ [ 20.216840] [sw_udc]: usb enter high speed. [ 20.216847] [sw_udc]: [ 20.216853] +++++++++++++++++++++++++++++++++++++ [ 20.221560] [sw_udc]: IRQ: reset [ 20.221582] [sw_udc]: irq: reset happen, throw away all urb [ 20.328833] [sw_udc]: Set address 2 [ 20.349966] RED Brick gadget: high-speed config #1: foobar [ 20.349986] [sw_udc]: ep enable: ep1(0x8074b884, ep1-bulk, 128, 512) [ 20.350007] [sw_udc]: ep enable: ep2(0x8074b8d0, ep2-bulk, 0, 512) [ 20.350032] [sw_udc]: ep enable: ep5(0x8074b9b4, ep5-int, 128, 10) [ 20.350047] [sw_udc]: ep enable: ep3(0x8074b91c, ep3-bulk, 128, 512) [ 20.350060] [sw_udc]: ep enable: ep4(0x8074b968, ep4-bulk, 0, 512) [ 20.350386] nuke: ep num is 0 [ 20.590202] WRN:L1355(drivers/usb/sunxi_usb/udc/sw_udc.c):handle_ep0: ep0 setup end [ 20.590223] nuke: ep num is 0 [ 20.590371] WRN:L1355(drivers/usb/sunxi_usb/udc/sw_udc.c):handle_ep0: ep0 setup end [ 20.590383] nuke: ep num is 0 [ 20.690717] WRN:L1355(drivers/usb/sunxi_usb/udc/sw_udc.c):handle_ep0: ep0 setup end [ 20.690739] nuke: ep num is 0 [ 31.442867] WRN:L1355(drivers/usb/sunxi_usb/udc/sw_udc.c):handle_ep0: ep0 setup end [ 31.442885] nuke: ep num is 0 [ 31.443019] WRN:L1355(drivers/usb/sunxi_usb/udc/sw_udc.c):handle_ep0: ep0 setup end [ 31.443030] nuke: ep num is 0 [ 31.543257] WRN:L1355(drivers/usb/sunxi_usb/udc/sw_udc.c):handle_ep0: ep0 setup end [ 31.543277] nuke: ep num is 0 [ 39.541770] incomplete xfer (0x20) [ 39.542301] incomplete xfer (0x20) [ 39.833241] bootchart-collector started as pid 2321 with 2 args: '--dump' '/tmp/bootchart.1wtZaXeI3P' [ 39.833258] Extracting profile data from pid 50 [ 39.833263] map 0x7e8d2000 -> 0x7e8f3000 size: 132k from '7e8d2000' '7e8f3000' [ 39.833269] read 135168 bytes of 135168 [ 39.833274] reading 21 chunks (of 21) ... wrote 2323 kb [ 39.833278] bootchart-collector pid: 2321 unmounted proc / clean exit [ 41.437063] WRN:L1355(drivers/usb/sunxi_usb/udc/sw_udc.c):handle_ep0: ep0 setup end [ 41.437085] nuke: ep num is 0 [ 44.426407] qf9700 3-1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xFFFF [ 44.588410] qf9700 3-1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xFFFF [ 53.253397] qf9700 3-1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xFFFF [ 54.834392] qf9700 3-1:1.0: eth0: link up, 100Mbps, full-duplex, lpa 0xFFFF [ 71.521012] [sw_udc]: alloc request: ep(0x8074b968, ep4-bulk, 512), req(0x9d1dc040) [ 71.521036] [sw_udc]: alloc request: ep(0x8074b968, ep4-bulk, 512), req(0x9d1dc840) [ 71.521047] [sw_udc]: alloc request: ep(0x8074b968, ep4-bulk, 512), req(0x9d1dcec0) [ 71.521057] [sw_udc]: alloc request: ep(0x8074b968, ep4-bulk, 512), req(0x9d1dc540) [ 71.521067] [sw_udc]: alloc request: ep(0x8074b968, ep4-bulk, 512), req(0x9d1dce40) [ 71.521078] [sw_udc]: alloc request: ep(0x8074b968, ep4-bulk, 512), req(0x9d1dc440) [ 71.521088] [sw_udc]: alloc request: ep(0x8074b968, ep4-bulk, 512), req(0x9d1dc080) [ 71.521100] [sw_udc]: alloc request: ep(0x8074b968, ep4-bulk, 512), req(0x9d1291c0) [ 71.521111] [sw_udc]: alloc request: ep(0x8074b968, ep4-bulk, 512), req(0x9d129d40) [ 71.521122] [sw_udc]: alloc request: ep(0x8074b968, ep4-bulk, 512), req(0x9d129980) [ 71.521133] [sw_udc]: alloc request: ep(0x8074b968, ep4-bulk, 512), req(0x9d129c40) [ 71.521144] [sw_udc]: alloc request: ep(0x8074b968, ep4-bulk, 512), req(0x9d129880) [ 71.521154] [sw_udc]: alloc request: ep(0x8074b968, ep4-bulk, 512), req(0x9d129940) [ 71.521165] [sw_udc]: alloc request: ep(0x8074b968, ep4-bulk, 512), req(0x9d129680) [ 71.521176] [sw_udc]: alloc request: ep(0x8074b968, ep4-bulk, 512), req(0x9d1296c0) [ 71.521194] [sw_udc]: alloc request: ep(0x8074b968, ep4-bulk, 512), req(0x9d129b00) [ 71.521205] [sw_udc]: alloc request: ep(0x8074b91c, ep3-bulk, 512), req(0x9d129540) [ 71.521215] [sw_udc]: alloc request: ep(0x8074b91c, ep3-bulk, 512), req(0x9d129a80) [ 71.521225] [sw_udc]: alloc request: ep(0x8074b91c, ep3-bulk, 512), req(0x9d1297c0) [ 71.521235] [sw_udc]: alloc request: ep(0x8074b91c, ep3-bulk, 512), req(0x9d129ec0) [ 71.521245] [sw_udc]: alloc request: ep(0x8074b91c, ep3-bulk, 512), req(0x9d129e80) [ 71.521255] [sw_udc]: alloc request: ep(0x8074b91c, ep3-bulk, 512), req(0x9d129ac0) [ 71.521265] [sw_udc]: alloc request: ep(0x8074b91c, ep3-bulk, 512), req(0x9d129b40) [ 71.521278] [sw_udc]: alloc request: ep(0x8074b91c, ep3-bulk, 512), req(0x9d1cec80) [ 71.521289] [sw_udc]: alloc request: ep(0x8074b91c, ep3-bulk, 512), req(0x9d1ce940) [ 71.521299] [sw_udc]: alloc request: ep(0x8074b91c, ep3-bulk, 512), req(0x9d1ce200) [ 71.521309] [sw_udc]: alloc request: ep(0x8074b91c, ep3-bulk, 512), req(0x9d1ce3c0) [ 71.521319] [sw_udc]: alloc request: ep(0x8074b91c, ep3-bulk, 512), req(0x9d1cec00) [ 71.521329] [sw_udc]: alloc request: ep(0x8074b91c, ep3-bulk, 512), req(0x9d1ce6c0) [ 71.521339] [sw_udc]: alloc request: ep(0x8074b91c, ep3-bulk, 512), req(0x9d1ce380) [ 71.521349] [sw_udc]: alloc request: ep(0x8074b91c, ep3-bulk, 512), req(0x9d1ce980) [ 71.521362] [sw_udc]: alloc request: ep(0x8074b91c, ep3-bulk, 512), req(0x9d1cebc0) Beachte, dass das Initialisieren der Ethernet Extension bei dir ziemlich lange dauert. Ich denke das sieht also alles normal aus bei dir. Aber wie schon in dem anderen Thread beschrieben, da gibt es noch reichlich Verbesserungspotential bzgl der Bootzeit, welches wir auch direkt nächstes Jahr umsetzen werden . Zitieren
