JavaLaurence Geschrieben November 3, 2014 at 13:38 Geschrieben November 3, 2014 at 13:38 Hi, The presence of which file(s) tell me whether or not a brick deamon has been installed correctly on a Raspberry ? Thx. Laurence Zitieren
remotecontrol Geschrieben November 3, 2014 at 15:43 Geschrieben November 3, 2014 at 15:43 You should have /usr/bin/brickd /etc/init.d/brickd and if brickd was started successfully there should be a log-file at /var/log/brickd.log You can start brickd also manually via sudo /etc/init.d/brickd start. Zitieren
JavaLaurence Geschrieben November 10, 2014 at 12:09 Autor Geschrieben November 10, 2014 at 12:09 Thanks for the answer. Zitieren
