excal2 Geschrieben October 15, 2014 at 08:50 Geschrieben October 15, 2014 at 08:50 I have a tinker forge dc brick , but I need to have it in two states , forward and reverse based on a switch. I can set it up in the openhab config but im not sure how to setup a second instance with a reverse velocity. Any help is appreciated Thanks Excal Zitieren
theo Geschrieben October 15, 2014 at 21:12 Geschrieben October 15, 2014 at 21:12 Hi excal2, I think you need two entries for the brick_dc in the openhab.cfg and items configuration. Furthermore you need two switches, one to switch on the forward configuration and one to switch on the reverse configuration of the brick. I've planned some enhanced support for brick_dc, but unfortunately this will take some month because currently I've no spare time to implement it. Regards, Theo Zitieren
excal2 Geschrieben October 18, 2014 at 20:05 Autor Geschrieben October 18, 2014 at 20:05 Hi Theo Thanks for that , I have tried putting two configs in the openhab.cfg but each time I add the 2nd one in the binding seems to throw an error, i guess it cant allow 2 configs for the same uid . Is there any other way I can get this to work? Many thanks Excal Zitieren
theo Geschrieben October 19, 2014 at 21:22 Geschrieben October 19, 2014 at 21:22 Hi excal2, for now there is now other solution, sorry for that. I will have time to work on this issue may be in 2 or 3 months. Sorry, Theo Zitieren
excal2 Geschrieben November 9, 2014 at 12:50 Autor Geschrieben November 9, 2014 at 12:50 Ahh that's really disappointing as this was the only reason I bought this device. Is there any plans to implement sooner? Zitieren
excal2 Geschrieben November 10, 2014 at 11:48 Autor Geschrieben November 10, 2014 at 11:48 Hi Theo Considering that all I now need is to control the direction of a dc motor , is there any other way that I can achieve this , maybe with stepper motor or a relay brick? As I'm using openhab this will control the time of the motor run. Just wondering if there is another solution to the problem. Any info is greatly appreciated Thanks Excal Zitieren
excal2 Geschrieben January 5, 2015 at 13:40 Autor Geschrieben January 5, 2015 at 13:40 Hi Theo Did you get the chance to work on this? Thanks Excal Zitieren
theo Geschrieben January 5, 2015 at 21:36 Geschrieben January 5, 2015 at 21:36 Hi Excal, thanks for reminding me. I started some work on RED Brick topic. As soon as this work is finished I will continue working on the binding. You will have to be patient for some more weeks. Regards, Theo Zitieren
theo Geschrieben January 31, 2015 at 17:38 Geschrieben January 31, 2015 at 17:38 Hi Excal, there are good news! There is a beta of the binding which has significantly improved support for the Brick DC. It comes with support for Dimmer, Rollershuter and Number items. Besides that the speed can also be set using a percent value. You will find a download link and some in this github issue: https://github.com/theoweiss/openhab/issues/1 Regards, Theo Zitieren
excal2 Geschrieben September 8, 2015 at 07:55 Autor Geschrieben September 8, 2015 at 07:55 Hi Theo Sorry just seen this , will give this a go tonight to see if it solves my issue. Fingers crossed!! Zitieren
theo Geschrieben September 10, 2015 at 21:05 Geschrieben September 10, 2015 at 21:05 Hi Excal, these features are released with openHAB 1.7. Therefore just install the newest openHAB release. Since 1.7 you can also control the Brick DC using rules and the new tinkerforge action bundle. Documentation and examples are here at the end of the file: https://github.com/openhab/openhab/wiki/Actions Regards, Theo Zitieren
excal2 Geschrieben October 9, 2015 at 11:45 Autor Geschrieben October 9, 2015 at 11:45 Hi Theo This works perfectly :-) Thanks a million for the help Excal Zitieren
