Hi all,
I received my IOT starter kit today and after initially getting it working I tried to update the master brick firmware. I put it into bootloader mode and connected it up, but my computer will not recognise the device, and Windows shows a prompt that the device has malfunctioned.
There are no indicator lights on on the device, and the device does go away in device manager when I unplug it. However, I am unable to install the drivers in the Brickv install location as Windows says the folder does not contain a suitable driver for my device.
Can anyone offer any advice on this?
So immediately after writing that, the device started working again.
The only thing that I did differently was disconnect the USB cable and remove and reseat the ethernet module on top. Then everything started working again.
I hope someone else finds this post useful.
