becker Geschrieben May 22, 2014 at 08:11 Geschrieben May 22, 2014 at 08:11 Hello there, the callback functionality of the SoundIntensity Bricklet will only fire if the measured value has changed. Thus I will not get measurements uniformly distributed over time (to calculate meaning ful averages). Is there a way to get continuous measurements (except maybe by actively querying every so often)? Thanks in advance. Best, Martin Zitieren
borg Geschrieben May 22, 2014 at 14:44 Geschrieben May 22, 2014 at 14:44 You can set the frequency of your measurements with set_debounce_period and then use the CALLBACK_INTENSITY_REACHED by setting an intensity threshold (set_intensity_callback_threshold) of something like "smaller than 4095", so it is always active. Zitieren
