Cathodion Geschrieben April 17, 2014 at 21:09 Geschrieben April 17, 2014 at 21:09 Hey Guys, In a couple of months my employer is moving to a new office space. Several weeks from now the building will be prepared for our needs, which is the perfect opportunity for me to install some tinkerforge stuff throughout the office. If I can come up with a reasonable plan my employer will consider this. What would be the best/cheapest way to connect about 8 to 10 separate master bricks with each other? Zitieren
Gast Robin Geschrieben April 18, 2014 at 13:01 Geschrieben April 18, 2014 at 13:01 The cheapest way would be using the RS485 Extension. It is much cheaper than the Wifi or Ethernet Extension if you want to connect multiple Bricks. But you need additional cables. Zitieren
