Fygo Geschrieben April 15, 2014 at 18:59 Geschrieben April 15, 2014 at 18:59 Hi everybody, Could somebody guide me how to save/count the orientation of the IMU Brick? Similarly to how brickv does it. I am trying to reproduce the same example with the 3D model with JS/Away3D/Actionscript. Seems to work "alright" not counting that my 3D models have different initial orientation so basically everything works the other way around (moving the brick left turns the object right, etc). I am retrieving the quaternions periodically and then pass them to flash where I convert them to a transformation 3D matrix and apply it to the models. Thanks in advance! Zitieren
borg Geschrieben April 15, 2014 at 20:10 Geschrieben April 15, 2014 at 20:10 Have you seen the IMU plugin on http://www.brickv.com/? I think it might do what you want. https://github.com/Tinkerforge/brickv.com/blob/master/js/brickv/plugins/PluginBrickIMU.js Zitieren
Fygo Geschrieben April 16, 2014 at 14:56 Autor Geschrieben April 16, 2014 at 14:56 Oh nice, thanks for that! However, still no go. I can save the position but the rotation is just broken. I guess the problem lies with the coordinate system. You are using a positive Z towards the user, is that correct? While Away3D has the positive Z facing away from the user. Unfortunately I have very few knowledge about these things (shame on me!), but I assume this would completely break the rotation. Is that so? Any hint/advance how to fix it? Edit: Here is how I am solving it: private function saveOrientation():void { var quatString:String = ExternalInterface.call("getQuaternionString"); //from JS in format "x,y,z,w" var quatArray:Array = quatString.split(","); _relX = -quatArray[0]; _relY = -quatArray[1]; _relZ = quatArray[2]; _relW = quatArray[3]; } And then upon update I use: var quatString:String = ExternalInterface.call("getQuaternionString"); //from JS in format "x,y,z,w" var quatArray:Array = quatString.split(","); var x:Number = -quatArray[0]; var y:Number = -quatArray[1]; var z:Number = quatArray[2]; var w:Number = -quatArray[3]; //there is a minus here, why? I have absolutely NO idea whether this is correct but it seems to work with a test cube. Is this approach at least remotely correct? All the rest of the calculation is from the example you showed me I am just not inverting the final transformation matrix (AS3: Matrix3D objects can be initialized with a Vector of 16 Numbers, where every four elements is a column.) Zitieren
borg Geschrieben April 16, 2014 at 20:39 Geschrieben April 16, 2014 at 20:39 I don't know Away3D, so i can't help you, sorry. But of course they can use a different coordinate system than we. If it works with the changes you did it probably only means that the positive facing direction of some of the axis is different, which shouldn't be a problem (i.e. you probably did the right thing). Zitieren
Fygo Geschrieben April 25, 2014 at 17:40 Autor Geschrieben April 25, 2014 at 17:40 Well, you are right, if it works, there is nothing to solve. Thanks for your assistance. One last question - any example/hint of how to smooth the quaternion values so I could eliminate the shakiness? Thanks a lot. Zitieren
borg Geschrieben April 25, 2014 at 18:03 Geschrieben April 25, 2014 at 18:03 Did you try to play around with the convergence speed? http://www.tinkerforge.com/en/doc/Software/Bricks/IMU_Brick_JavaScript.html#BrickIMU.setConvergenceSpeed Zitieren
Fygo Geschrieben April 25, 2014 at 19:00 Autor Geschrieben April 25, 2014 at 19:00 Jeez, that's it. Very nice, thanks a lot! Zitieren
