kwally Geschrieben April 9, 2014 at 05:06 Geschrieben April 9, 2014 at 05:06 Ja meine lieben. Ich habe for kurzter zeit eine illusion gehapt das ich ENDLICH das raetsel geloest habe. Das ist, die wetter stations functioniert; Drop Box Connection hat endlich geklappt; aber leider das Python script kann nicht die connection mit tinkerforge_ip connection fertig bringen. Es waerde sehr schoen wenn jemand von den Tinkerforge Kunden wissen was falsch ist. Das script habe ich nicht selber geschrieben, Gott sei dank, aber habe vom Internet abgeladen. http://tinyurl.com/mxw8omx heisst Main.py und upload.py Es schtolpert immer bei dem "tinkerforge.ip_connection. Hiermit die "Error message" live and kicking' Traceback (most recent call last): File "main.py", line 111, in <module> main() File "main.py", line 91, in main light_level=light_sensor.get_illuminance()/10.0 File "/usr/local/lib/python2.7/dist-packages/tinkerforge.egg/tinkerforge/bricklet_ambient_light.py", line 103, in get_illuminance File "/usr/local/lib/python2.7/dist-packages/tinkerforge.egg/tinkerforge/ip_connection.py", line 878, in send_request tinkerforge.ip_connection.Error: -1: Did not receive response for function 1 in time Exception in thread Disconnect-Prober (most likely raised during interpreter shutdown):Exception in thread Brickd-Receiver (most likely raised during interpreter shutdown): Traceback (most recent call last): File "/usr/lib/python2.7/threading.py", line 552, in __bootstrap_inner File "/usr/lib/python2.7/threading.py", line 505, in runTraceback (most recent call last): File "/usr/local/lib/python2.7/dist-packages/tinkerforge.egg/tinkerforge/ip_connection.py", line 617, in receive_loop File "/usr/lib/python2.7/threading.py", line 552, in __bootstrap_inner <type 'exceptions.TypeError'>: 'NoneType' object is not callable File "/usr/lib/python2.7/threading.py", line 505, in run File "/usr/local/lib/python2.7/dist-packages/tinkerforge.egg/tinkerforge/ip_connection.py", line 752, in disconnect_probe_loop File "/usr/lib/python2.7/Queue.py", line 174, in get <type 'exceptions.TypeError'>: 'NoneType' object is not callable Hoffentlich gibts jemand der weiss was da los ist? Vieln Dank Karl Zitieren
borg Geschrieben April 9, 2014 at 07:19 Geschrieben April 9, 2014 at 07:19 Funktioniert das Ambient Light Bricklet im Brick Viewer? Ist die UID "am9" für das Ambient Light Bricklet korrekt? Zitieren
kwally Geschrieben April 9, 2014 at 22:24 Autor Geschrieben April 9, 2014 at 22:24 Ja alle Bricklets sehe ich im Brickview. Die bricklet addressen habe ich natuerlich umgeandert.Master ist 6xftxf,licht ist mbr,Temp ist dY7 Baro ist k4s and Humidity ist keV. Aber das script hat ja die Humidity nicht drinnen. Ich habe gedacht bestens warten bis ich es erstmal functioniert, before ich probiere die Humidity reingeben. Ich weiss ja nicht was der richtige Syntax ist. Danke fuer die antwort. Zitieren
kwally Geschrieben April 10, 2014 at 02:29 Autor Geschrieben April 10, 2014 at 02:29 Habe den fehler schon gefunden. Mea culpa mea culpa mea maxima culpa. Hast schon recht gehabt Borg. Die UID ist mbR und ich habe mbr reingetan. Wie kann man so bloed sein!! Aber ich wuerde sehr dankbar sein fuer den richtigen syntax fuer die Humidity bricklet. Karl Zitieren
