Weiss jemand wo man die dependenciess die mit qt4 qwt gl et cetera finden kann?
Ich reiss mir schon bald die haare aus!! Mir kommt es vor das die ein part von Python sind. Leider kann die Brickview installer nicht finden??
Vielen dank
Karl
Die saga geht weiter. Ich habe hiermit die letzte erro message:
  Package python-qt4 is not installed.
brickv depends on python-qt4-gl; however:
  Package python-qt4-gl is not installed.
brickv depends on python-qwt5-qt4; however:
  Package python-qwt5-qt4 is not installed.
brickv depends on python-opengl; however:
  Package python-opengl is not installed.
brickv depends on python-serial; however:
  Package python-serial is not installed.
dpkg: error processing brickv (--install):
dependency problems - leaving unconfigured
Processing triggers for desktop-file-utils ...
Errors were encountered while processing:
Danke mOb
Das geht leider nicht hiermit das resultat:
pi@raspberrypi ~ $ sudo apt-get install python python-qt4 python-qt4-gl python-qwt5-qt4 python-opengl python-serial pyqt4-dev-tools
Reading package lists... Done
Building dependency tree
Reading state information... Done
python is already the newest version.
You might want to run 'apt-get -f install' to correct these:
The following packages have unmet dependencies:
python-opengl : Depends: libglu1-mesa but it is not going to be installed or
                          libglu1
                Depends: freeglut3 but it is not going to be installed
python-qt4 : Depends: libqt4-declarative (>= 4:4.8.0-1~) but it is not going to be installed
              Depends: libqt4-designer (>= 4:4.8.0-1~) but it is not going to be installed
              Depends: libqt4-help (>= 4:4.8.0-1~) but it is not going to be installed
              Depends: libqt4-script (>= 4:4.8.0-1~) but it is not going to be installed
              Depends: libqt4-scripttools (>= 4:4.8.0-1~) but it is not going to be installed
              Depends: libqt4-test (>= 4:4.8.0-1~) but it is not going to be installed
              Depends: libqt4-xmlpatterns (>= 4:4.8.0-1~) but it is not going to be installed
              Depends: libqtassistantclient4 (>= 4.6.3) but it is not going to be installed
              Depends: sip-api-8.1
python-qt4-gl : Depends: libqt4-opengl (>= 4:4.8.0-1~) but it is not going to be installed
python-qwt5-qt4 : Depends: libqwt5-qt4 (>= 5.2.2) but it is not going to be installed
                  Recommends: libqwt-dev but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
pi@raspberrypi ~ $
Danke Borg, muss was los sein mit meiner NOOB's installation. Ich habe auch eine neue SD card gekauft das NOOBS draufgegeben aber die Raspberry magt die carte nicht und will nichts installieren.Ich glaubte das ich eine loesung hatte mit:
sudo apt-get _f install python-twisted aber bekomme ich die folgende error message:
Err http://mirrordirector.raspbian.org/raspbian/ wheezy/main mysql-common all 5.5.33+dfsg-0+wheezy1
  404  Not Found
Err http://mirrordirector.raspbian.org/raspbian/ wheezy/main libmysqlclient18 armhf 5.5.33+dfsg-0+wheezy1
  404  Not Found
Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/m/mysql-5.5/mysql-common_5.5.33+dfsg-0+wheezy1_all.deb  404  Not Found
Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/m/mysql-5.5/libmysqlclient18_5.5.33+dfsg-0+wheezy1_armhf.deb  404  Not Found
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-mi
Ich kaufe mir noch eine andere SD carte und versuchs nochmal vom anfang. Die letzte die nicht funktionierte war eine Verbatim. Danke, Karl
sudo apt-get -f install
Correcting dependencies... Done
The following extra packages will be installed:
  freeglut3 libgl1-mesa-dev libglu1-mesa libglu1-mesa-dev libmysqlclient18
  libpthread-stubs0 libpthread-stubs0-dev libqt4-declarative libqt4-designer
  libqt4-dev libqt4-dev-bin libqt4-help libqt4-opengl libqt4-opengl-dev
  libqt4-qt3support libqt4-script libqt4-scripttools libqt4-sql
  libqt4-sql-mysql libqt4-test libqt4-xmlpatterns libqtassistantclient4
  libqtwebkit-dev libqwt-dev libqwt5-qt4 libqwt6 libx11-dev libx11-doc
  libxau-dev libxcb1-dev libxdmcp-dev libxext-dev mesa-common-dev mysql-common
  python-opengl python-qt4 python-qt4-gl python-qwt5-qt4 python-serial
  python-sip qt4-linguist-tools qt4-qmake x11proto-core-dev x11proto-input-dev
  x11proto-kb-dev x11proto-xext-dev xorg-sgml-doctools xtrans-dev
Suggested packages:
  libqt4-declarative-folderlistmodel libqt4-declarative-gestures
  libqt4-declarative-particles libqt4-declarative-shaders qt4-qmlviewer
  firebird-dev libmysqlclient-dev libpq-dev libsqlite0-dev libsqlite3-dev
  qt4-dev-tools qt4-doc unixodbc-dev libxcb-doc libxext-doc libgle3
  python-qt4-dbg python-wxgtk2.8 python-wxgtk2.6 python-wxgtk
The following NEW packages will be installed:
0 upgraded, 48 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 703 kB/26.8 MB of archives.
After this operation, 106 MB of additional disk space will be used.
Do you want to continue [Y/n]? y
  404  Not Found
  404  Not Found
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
pi@raspberrypi ~ $
