kwally Geschrieben March 19, 2014 at 02:02 Geschrieben March 19, 2014 at 02:02 For the life of me I can't get brickview to install.I keep getting the same error message: pi@raspberrypi ~ $ sudo apt-get install python python-qt4 python-qt4-gl python-qwt5-qt4 python-opengl python-serial Reading package lists... Done Building dependency tree Reading state information... Done python is already the newest version. python-serial is already the newest version. python-serial set to manually installed. You might want to run 'apt-get -f install' to correct these: The following packages have unmet dependencies: python-opengl : Depends: libglu1-mesa but it is not going to be installed or libglu1 Depends: freeglut3 but it is not going to be installed python-qt4 : Depends: libqt4-declarative (>= 4:4.8.0-1~) but it is not going to be installed Depends: libqt4-designer (>= 4:4.8.0-1~) but it is not going to be installed Depends: libqt4-help (>= 4:4.8.0-1~) but it is not going to be installed Depends: libqt4-script (>= 4:4.8.0-1~) but it is not going to be installed Depends: libqt4-scripttools (>= 4:4.8.0-1~) but it is not going to be installed Depends: libqt4-test (>= 4:4.8.0-1~) but it is not going to be installed Depends: libqt4-xmlpatterns (>= 4:4.8.0-1~) but it is not going to be installed Depends: libqtassistantclient4 (>= 4.6.3) but it is not going to be installed Depends: sip-api-8.1 python-qt4-gl : Depends: libqt4-opengl (>= 4:4.8.0-1~) but it is not going to be installed python-qwt5-qt4 : Depends: libqwt5-qt4 (>= 5.2.2) but it is not going to be installed Depends: sip-api-8.1 Recommends: libqwt-dev but it is not going to be installed E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution). pi@raspberrypi ~ $ sudo apt-get install python python-qt4 python-qt4-gl python-qwt5-qt4 python-op Has anyone got a solution? Much appreciated Zitieren
kwally Geschrieben March 19, 2014 at 03:29 Autor Geschrieben March 19, 2014 at 03:29 I keep getting the same error message no matter what permutation I try. This apparently stopd my Brickv from installing.Her it is The following packages have unmet dependencies: brickv : Depends: python-qt4 but it is not going to be installed Depends: python-qt4-gl but it is not going to be installed Depends: python-qwt5-qt4 but it is not going to be installed Depends: python-opengl but it is not going to be installed pm-utils : Depends: powermgmt-base but it is not going to be installed Recommends: vbetool but it is not installable Recommends: hdparm but it is not going to be installed E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution) Are you there Remote Control? Zitieren
Loetkolben Geschrieben March 19, 2014 at 06:55 Geschrieben March 19, 2014 at 06:55 Have you tried the recommendation from above? E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution). Der Loetkolben Zitieren
kwally Geschrieben March 19, 2014 at 07:08 Autor Geschrieben March 19, 2014 at 07:08 Danke Loetkolben. Ja hab ich schon probiert. Aus meiner verzweiflung habe ich mein 16 Gig Sandisk formatted and started all over again following judiciously the instruction on Tinkerforge. I thought I had it; when I got to the stage of answering wether or not I agree to surrendering some 550 odd meg of disk space. I happily selected y for yes !!! wait for it! I got and "abort" Why for heavens sake?? I thought perhaps answering n for no would do it; but no it resulted in the same "abort" responds. I have a newly formatted 60 gig Sandisk? Sorry, I am not sure if you prefer english. Let me know. I live in Brisbane/Australia. Though I do speak German. Cheers Karl Zitieren
borg Geschrieben March 19, 2014 at 08:22 Geschrieben March 19, 2014 at 08:22 What error do you get if you run "apt-get -f install"? What distribution are you using for your RPi? Zitieren
photron Geschrieben March 19, 2014 at 16:47 Geschrieben March 19, 2014 at 16:47 Did you try apt-get -f install as suggested? Zitieren
kwally Geschrieben March 19, 2014 at 22:15 Autor Geschrieben March 19, 2014 at 22:15 I use Python 3.2 I think. The one that installs from NOOBS, it just offers Python at install doesn't say which version. The SD card is a 16 gig Sandisk Xtra speed. I have gone back and re-formatted and re-installed NOOBS twice. It just will not install the qt4 qt5gl et cetera. The brickdeamon installed okay. There is also a Brickv Icon in my "other" directory but clicking on it produces nothing, it is just a shortcut, that seems to be leading nowhere. Thanks for trying. The -f switch seems to make no difference. Zitieren
kwally Geschrieben March 20, 2014 at 00:20 Autor Geschrieben March 20, 2014 at 00:20 Yes I tried the -f switch I think these files are missing on my RPi (Python 3.2) Would be nice if someone knew where to find them! Zitieren
kwally Geschrieben March 20, 2014 at 03:59 Autor Geschrieben March 20, 2014 at 03:59 It doesn't seem to matter what call I make the same error report appears: The following packages have unmet dependencies: brickv : Depends: python-qt4 but it is not going to be installed Depends: python-qt4-gl but it is not going to be installed Depends: python-qwt5-qt4 but it is not going to be installed Depends: python-opengl but it is not going to be installed Depends: python-serial but it is not going to be installed E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution). # note: the –f switch makes no difference I got the same message when trying to install geany.i.e. sudo apt-get install geany. Thank you chaps Zitieren
borg Geschrieben March 20, 2014 at 08:36 Geschrieben March 20, 2014 at 08:36 Brick Viewer (as well as python-qwt*) needs Python 2.X, that might be your problem. But you can install Python 3.X and Python 2.X at the same time! Zitieren
kwally Geschrieben March 25, 2014 at 00:02 Autor Geschrieben March 25, 2014 at 00:02 The following proved to resolve this issue: Run this first: sudo apt-get install libusb-1.0-0 libudev0 pm-utils Wait till this process finishes !! then run: wget http://download.tinkerforge.com/tools/brickd/linux/brickd_linux_latest_armhf.deb sudo dpkg -i brickd_linux_latest_armhf.deb Again, wait till this is done, then run: sudo apt-get -f install python python-qt4 python-qt4-gl python-qwt5-qt4 python-opengl python-serial Wait till done, then run: wget http://download.tinkerforge.com/tools/brickv/linux/brickv_linux_latest.deb sudo dpkg -i brickv_linux_latest.deb Cheers Zitieren
