jose1711 Geschrieben November 12, 2013 at 15:17 Geschrieben November 12, 2013 at 15:17 hello, how many physical (dis)connects are brick(let) connectors designed for? also, is it safe to (dis)connect bricklets to master bricks on the go? thank you, jose Zitieren
borg Geschrieben November 12, 2013 at 15:23 Geschrieben November 12, 2013 at 15:23 how many physical (dis)connects are brick(let) connectors designed for? Unfortunately i can't find any information on that in the manufacturer datasheet: www.jst-belgium.be/downloads/series/eSH_3.pdf But we have Master Bricks here that are used for flashing that have Bricklets connected/disconnected to them several thousand times and they still work OK. also, is it safe to (dis)connect bricklets to master bricks on the go? No! In general Bricklet hotplug is not possible. It is only recommended in situations where a broken firmware is on a Bricklet and it needs to be reflashed with a working firmware. Zitieren
