Could you add a larger mounting plate to your shop? Preferable one that is at least 4 times larger then the current largest one. I can always saw a bit off when its to big. The current plates arent big enough to fit a master brick and a single io16 bricklet. Also, I would like to mount a master brick and several dual relay bricklets on 1 plate.
Hope you can make this happen.
Kind regards,
Geert Schuring.
