riklaunim Geschrieben September 1, 2013 at 14:16 Geschrieben September 1, 2013 at 14:16 There are various mini robots like Tamiya or other that use low power DC motors. The DC brick can handle one 28V and 5A peak motor for 49,99 EUR. To control 4 motor robot kit it would require 200 EUR, while each motor is usually below 1A and like 3-5V. I've seen cheaper DC controllers for such weaker motors (cheaper than those for bigger amps motors). Maybe there could be a low-power-DC brick that would allow controlling those robot kits without spending insane amount of money? Zitieren
borg Geschrieben September 2, 2013 at 08:41 Geschrieben September 2, 2013 at 08:41 We did think about a version of the Servo Brick that has power on the actual PWM pins (not only on the third VCC pin). The idea there was that you could control up to 7 high power LEDs with it, additionally to servos. You could also control small motors. But this won't happen in the next weeks, we currently have too many other open project. Zitieren
pwab Geschrieben July 18, 2018 at 13:08 Geschrieben July 18, 2018 at 13:08 Sorry for digging this topic up but is this still a point on your todo-list? Overall, there seems to be an interest here on the board: - https://www.tinkerunity.org/forum/index.php/topic,4181.msg24600.html - https://www.tinkerunity.org/forum/index.php/topic,3825.msg22857.html - https://www.tinkerunity.org/forum/index.php/topic,4412.msg25511.html (own topic ) - https://www.tinkerunity.org/forum/index.php/topic,4049.msg24051.html - https://www.tinkerunity.org/forum/index.php/topic,4036.msg24007.html - https://www.tinkerunity.org/forum/index.php/topic,2690.msg17256.html - https://www.tinkerunity.org/forum/index.php/topic,528.msg2946.html I would really love using such a brick for robots and other small dc-motor-projects. Zitieren
pwab Geschrieben October 6, 2020 at 05:33 Geschrieben October 6, 2020 at 05:33 Still interested 😅 Zitieren
