ich versuche gerade die Master-Firmware zu kompilieren, scheitere aber an der generate_makefile.bat...
Ich erhalte bei der Ausführung folgende Fehler:
C:\Users\Monti\Programmieren\master-brick-master\master-brick-master\software>cmake -E chdir build/ cmake -G "MinGW Makefiles" -DCMAKE_TOOLCHAIN_FILE=toolchains/arm-none-eabi.cmake ../
CMake Error: CMake was unable to find a build program corresponding to "MinGW Makefiles".  CMAKE_MAKE_PROGRAM is not set.  You probably need to select a different build tool.
CMake Error: Error required internal CMake variable not set, cmake may be not be built correctly.
Missing variable is:
CMAKE_C_COMPILER_ENV_VAR
CMAKE_C_COMPILER
CMake Error: Could not find cmake module file:C:/Users/Monti/Programmieren/master-brick-master/master-brick-master/software/build/CMakeFiles/2.8.11.2/CMakeCCompiler.cmake
CMAKE_CXX_COMPILER_ENV_VAR
CMAKE_CXX_COMPILER
CMake Error: Could not find cmake module file:C:/Users/Monti/Programmieren/master-brick-master/master-brick-master/software/build/CMakeFiles/2.8.11.2/CMakeCXXCompiler.cmake
-- Configuring incomplete, errors occurred!
CMake Error: CMAKE_C_COMPILER not set, after EnableLanguage
CMake Error: CMAKE_CXX_COMPILER not set, after EnableLanguage
Eventuell wichtig:
Ich benutze Windows 8 (64-Bit)...
