Riffhai Geschrieben November 23, 2016 at 19:40 Geschrieben November 23, 2016 at 19:40 Das habe ich gefunden im LOG [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.event.EventHandler, org.osgi.service.cm.ManagedService, id=330, bundle=211/mvn:org.openhab.binding/org.openhab.binding.tinkerforge/1.9.0.b4]: Updating property uv of configuration org.openhab.tinkerforge caused a problem: unknown device type: bricklet_uv_light org.osgi.service.cm.ConfigurationException: uv : unknown device type: bricklet_uv_light at org.openhab.binding.tinkerforge.internal.config.ConfigurationHandler.checkTfType(ConfigurationHandler.java:840)[211:org.openhab.binding.tinkerforge:1.9.0.b4] at org.openhab.binding.tinkerforge.internal.config.ConfigurationHandler.createConfigContainer(ConfigurationHandler.java:263)[211:org.openhab.binding.tinkerforge:1.9.0.b4] at org.openhab.binding.tinkerforge.internal.config.ConfigurationHandler.createConfig(ConfigurationHandler.java:207)[211:org.openhab.binding.tinkerforge:1.9.0.b4] at org.openhab.binding.tinkerforge.internal.TinkerforgeBinding.updated(TinkerforgeBinding.java:887)[211:org.openhab.binding.tinkerforge:1.9.0.b4] at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189)[7:org.apache.felix.configadmin:1.8.8] at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152)[7:org.apache.felix.configadmin:1.8.8] at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85)[7:org.apache.felix.configadmin:1.8.8] at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1444)[7:org.apache.felix.configadmin:1.8.8] at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1400)[7:org.apache.felix.configadmin:1.8.8] at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:143)[7:org.apache.felix.configadmin:1.8.8] at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:110)[7:org.apache.felix.configadmin:1.8.8] at java.lang.Thread.run(Thread.java:745)[:1.8.0_65] Zitieren
theo Geschrieben November 23, 2016 at 19:57 Autor Geschrieben November 23, 2016 at 19:57 Bitte auch für openHAB2 das Binding auf den Snapshot aktualisieren, die Fixes und Erweiterungen sind noch nicht gemerged. Zitieren
Riffhai Geschrieben November 24, 2016 at 06:36 Geschrieben November 24, 2016 at 06:36 ich habe den aktuellen Snapshot in den addons Ordner kopiert jetzt kommt ein Fehler muss ich in der Paper Ui das Tinkerforge Bindung vorher deinstallieren? [ERROR] [org.openhab.binding.tinkerforge ] - FrameworkEvent ERROR - org.openhab.binding.tinkerforge org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.tinkerforge [227] Another singleton bundle selected: osgi.identity; osgi.identity="org.openhab.binding.tinkerforge"; type="osgi.bundle"; version:Version="1.9.0.b4"; singleton:="true" nach einem Neustart funktionieren die Schaltsteckdosen sonst nix Zitieren
Gast sihui Geschrieben November 24, 2016 at 18:28 Geschrieben November 24, 2016 at 18:28 muss ich in der Paper Ui das Tinkerforge Bindung vorher deinstallieren? Ja. Zitieren
Gast sihui Geschrieben November 24, 2016 at 18:34 Geschrieben November 24, 2016 at 18:34 By the way, wenn ich mir dein Log anschaue dann scheinst du die Beta zu nutzen und nicht die Snapshot Versionen ... Ist grundsätzlich eine ganz schlechte Idee: die Beta ist inzwischen uralt und in den Snapshot Releases sind massenhaft Verbesserungen eingeflossen. Also mal bei Gelegenheit über https://openhab.ci.cloudbees.com/job/openHAB-Distribution/ nachdenken. Gruß, Sigi Zitieren
Riffhai Geschrieben November 24, 2016 at 18:47 Geschrieben November 24, 2016 at 18:47 Ich habe openhab2 wie hier beschrieben installiert http://docs.openhab.org/installation/linux.html ich setze Openhab neu auf ich hoffe dass ich die richtige Version erwische. Ich habe mit apt-get installiert und nicht wie bei Openhab1 alles in opt/openhab kopiert. Jetzt erinnere ich mich ich habe die Beta Version wo kann ich im System erkennen welche Version ich habe Danke für die Hilfe ! Wenn ich ein Backup mache und die conf sichere und dann wieder reinkopiere dann sind doch meine Geräte noch da ? oder macht er von kompletten System ein Backup? Zitieren
Riffhai Geschrieben November 24, 2016 at 19:22 Geschrieben November 24, 2016 at 19:22 habe neu installiert jetzt aber die richtige Snapshot Version Zitieren
Riffhai Geschrieben November 24, 2016 at 20:13 Geschrieben November 24, 2016 at 20:13 Ich bekomme diesen Fehler [ERROR] [org.apache.felix.configadmin ] - [org.osgi.service.event.EventHandler, org.osgi.service.cm.ManagedService, id=294, bundle=193/mvn:org.openhab.binding/org.openhab.binding.tinkerforge/1.9.0-SNAPSHOT]: Updating property uv of configuration org.openhab.tinkerforge caused a problem: unknown device type: bricklet_uv_light org.osgi.service.cm.ConfigurationException: uv : unknown device type: bricklet_uv_light at org.openhab.binding.tinkerforge.internal.config.ConfigurationHandler.checkTfType(ConfigurationHandler.java:840)[193:org.openhab.binding.tinkerforge:1.9.0.201611240211] at org.openhab.binding.tinkerforge.internal.config.ConfigurationHandler.createConfigContainer(ConfigurationHandler.java:263)[193:org.openhab.binding.tinkerforge:1.9.0.201611240211] at org.openhab.binding.tinkerforge.internal.config.ConfigurationHandler.createConfig(ConfigurationHandler.java:207)[193:org.openhab.binding.tinkerforge:1.9.0.201611240211] at org.openhab.binding.tinkerforge.internal.TinkerforgeBinding.updated(TinkerforgeBinding.java:887)[193:org.openhab.binding.tinkerforge:1.9.0.201611240211] at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updated(ManagedServiceTracker.java:189)[7:org.apache.felix.configadmin:1.8.8] at org.apache.felix.cm.impl.helper.ManagedServiceTracker.updateService(ManagedServiceTracker.java:152)[7:org.apache.felix.configadmin:1.8.8] at org.apache.felix.cm.impl.helper.ManagedServiceTracker.provideConfiguration(ManagedServiceTracker.java:85)[7:org.apache.felix.configadmin:1.8.8] at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.provide(ConfigurationManager.java:1444)[7:org.apache.felix.configadmin:1.8.8] at org.apache.felix.cm.impl.ConfigurationManager$ManagedServiceUpdate.run(ConfigurationManager.java:1400)[7:org.apache.felix.configadmin:1.8.8] at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:143)[7:org.apache.felix.configadmin:1.8.8] at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:110)[7:org.apache.felix.configadmin:1.8.8] at java.lang.Thread.run(Thread.java:745)[:1.8.0_65] Ich habe das Binding über die Paper UI Installiert und ein Häkchen Include Legacy 1.x Bindings gemacht auch schon ohne Häkchen probiert die cfg und items kopiert es zeigt nichts an. Zitieren
Riffhai Geschrieben November 24, 2016 at 20:45 Geschrieben November 24, 2016 at 20:45 Oh man, jetzt habe ich ein apt-get update und apt-get upgrade gemacht und jetzt startet mir das Openhab2 nicht mehr jetzt muss ich mal im Openhab Forum schauen Zitieren
Gast sihui Geschrieben November 25, 2016 at 08:00 Geschrieben November 25, 2016 at 08:00 Ich bekomme diesen Fehler Auch mit dem Snapshot gilt: für die Beseitigung des Problems mit dem UV Bricklet musst du weiterhin das überarbeitete Binding in dem von Theo geposteten Link verwenden. Erst wenn diese Änderungen gemerged sind fliessen sie in die Snapshot Version ein und DANN kannst du das Binding aus dem addons Ordner entfernen und das über PaperUI angezeigte installieren. Zusammegefasst: das von Theo gepostete Tinkerforge Snapshot Binding ist erst dann das Snapshot Binding aus der PaperUI, wenn die Änderungen eingeflossen, also gemerged sind. Zitieren
Gast sihui Geschrieben November 25, 2016 at 08:02 Geschrieben November 25, 2016 at 08:02 jetzt startet mir das Openhab2 nicht mehr Wie ich sehe ist das Problem ja inzwischen auch gelöst Zitieren
Riffhai Geschrieben November 25, 2016 at 09:08 Geschrieben November 25, 2016 at 09:08 ja openhab geht wieder nur Tinkerforge immer noch nicht Zitieren
Gast sihui Geschrieben November 25, 2016 at 09:38 Geschrieben November 25, 2016 at 09:38 ja openhab geht wieder nur Tinkerforge immer noch nicht Hast du denn das Snapshot Binding aus Theo's Link installiert? Zitieren
Riffhai Geschrieben November 25, 2016 at 12:11 Geschrieben November 25, 2016 at 12:11 Ich habe das Binding in den Ordner kopiert und das Binding in der Paper UI deinstalliert jetzt gehen die Bricklets die mit LAN am Netz hängen aber alle anderen die mit der WIFI Master Extension 2.0 verbunden sind werden mir nicht angezeigt. Sie gehen aber im Brick Viewer. Habe den Stapel vom Netzt genommen und neu gestartet jetzt geht es !!!! Zitieren
Riffhai Geschrieben December 12, 2016 at 14:26 Geschrieben December 12, 2016 at 14:26 Hallo, warum zeigt mir das Ambient Light Bricklet 2.0 im Viewer einen Wert von 7,5 lx Openhab zeigt mir einen Wert von 75 lx ich muss doch bestimmt im Item was verändern aber nur was ? Zitieren
Gast sihui Geschrieben December 14, 2016 at 06:21 Geschrieben December 14, 2016 at 06:21 ich muss doch bestimmt im Item was verändern aber nur was ? Unwahrscheinlich. Es gibt keine Parameter um das zu konfigurieren. Das dürfte dann wohl ein Fehler im Viewer oder im Binding sein. Was sagt denn dein event.log? Dort müsste ja irgendwo etwas in der Art Illuminance changed from 79.5 to 75.0 stehen (oder so ähnlich, ich habe dieses Bricklet nicht). Oder veränderst du die Werte -versehentlich- über eine Rule? Zitieren
Riffhai Geschrieben December 16, 2016 at 11:14 Geschrieben December 16, 2016 at 11:14 Im event.log steht [itemStateChangedEvent ] - Helligkeit_TF changed from 124.7 to 125.9 im Viewer 12.59 es ist egal ob mit Openhab1 oder 2 immer das gleiche das Komma ist an der falschen Stelle. Zitieren
theo Geschrieben December 16, 2016 at 21:17 Autor Geschrieben December 16, 2016 at 21:17 Ist vermutlich ein Bug im Binding, ich schau mir das mal an. Zitieren
theo Geschrieben January 9, 2017 at 20:18 Autor Geschrieben January 9, 2017 at 20:18 Hier ist ein Binding das die Lux Werte für das Ambient Light Bricklet 2.0 richtig wiedergeben sollte: https://bintray.com/theoweiss/generic/download_file?file_path=ambiV2Lux%2Forg.openhab.binding.tinkerforge-1.9.0-SNAPSHOT.jar @Riffhai kannst du bitte testen ob es damit funktioniert. Zitieren
Riffhai Geschrieben January 16, 2017 at 16:52 Geschrieben January 16, 2017 at 16:52 Hallo Theo, es funktioniert, Danke. Zitieren
Einstein Geschrieben January 30, 2017 at 20:53 Geschrieben January 30, 2017 at 20:53 @theo kannst du schon was zum stand für openhab 2.0 sagen? Zitieren
Gast sihui Geschrieben January 31, 2017 at 11:31 Geschrieben January 31, 2017 at 11:31 zum stand für openhab 2.0 sagen? openHAB2 ist inzwischen als stable veröffentlicht Oder meinst du das Tinkerforge Binding? Grinsender Gruß, Sigi P.S.: Was fehlt dir den eventuell im TF Binding? Autodiscovery? Abgesehen davon funktioniert das 1.x Binding fantastisch mit openHAB2 ... Zitieren
theo Geschrieben February 1, 2017 at 21:32 Autor Geschrieben February 1, 2017 at 21:32 Hallo @Einstein, ich habe zu openHAB 2 kürzlich eine Frage hier im Forum beantwortet (http://www.tinkerunity.org/forum/index.php/topic,3957.msg23686.html#msg23686). Ich poste das Wesentliche einfach noch mal hier: Das TinkerForge Binding funktioniert natürlich auch in openHAB2 und ist Teil der Distribution. Es ist aber noch kein natives OH2 Binding, d.h. Autodiscovery und Konfiguration über das Web-Interface werden nicht unterstützt. Für alte Hasen sollte das kein Problem sein, da sie im wesentlichen wie bei OH1 vorgehen. Cool sind die neuen Features ganz sicher und passen sehr gut zu den TinkerForge Möglichkeiten. Ich will die Portierung machen, aber das bedeutet vermutlich eine komplette Reimplemetierung des Bindings und dazu hat es mir bisher an der Zeit gefehlt - auch weil ich weitere Maintainer-Aufgaben bei openHAB übernommen habe. Ich bräuchte einfach mal eine Woche am Stück Zeit, dann wäre sicher einiges geschafft. Mit Familie und Vollzeitjob ist das aber nicht drin, d.h. da kann noch ein halbes bis ein Jahr ins Land gehen :-(( Die beste Nachricht ist, dass alle Erweiterungen und Fixes die ich im letzten Jahr gemacht habe auch mit OH2 Released wurden. Beispielkonfigurationen findet ihr hier https://github.com/theoweiss/openhab2-tinkerforge-configuration-examples. Die offizielle Doku dazu wird in Kürze unter http://docs.openhab.org/addons/bindings.html zur Verfügung stehen. Da hat dankenswerterweise @sihui sehr viel dazu beigetragen. Gruß, Theo Zitieren
Einstein Geschrieben February 3, 2017 at 22:20 Geschrieben February 3, 2017 at 22:20 @theo danke dir auch für die ganze arbeit/mühe die du dir machst Zitieren
Oxylomorph Geschrieben February 7, 2017 at 22:55 Geschrieben February 7, 2017 at 22:55 Vielen Dank dir theo für das Engagement und die gute Arbeit am OpenHAB/2 Binding. Das führt mich aber zur Frage die mehr in Richtung Tinkerforge gerichtet ist. Ist auch angedacht OpenHAB2 in den RedBrick zu integrieren? Natürlich, man kann OH2 prinzipiell auch aktuell schon dort laufen lassen. Eine mögliche Unterstützung und Konfiguration über den Brick Viewer wäre aber wohl unbestritten etwas komfortabler. Zitieren
