JavaLaurence Geschrieben June 23, 2013 at 09:50 Geschrieben June 23, 2013 at 09:50 Can the Wifi and Ethernet extensions be combined in any interesting ways, or are they mutually exclusive? Zitieren
borg Geschrieben June 24, 2013 at 13:39 Geschrieben June 24, 2013 at 13:39 You can use them in the same LAN, but that is about it . Zitieren
JavaLaurence Geschrieben June 24, 2013 at 18:41 Autor Geschrieben June 24, 2013 at 18:41 I meant in the same stack? Zitieren
batti Geschrieben June 25, 2013 at 05:38 Geschrieben June 25, 2013 at 05:38 They aren't usable in the same stack. You can use them together with RS485 but not WiFi and LAN together. The reason for it is, that there is only one extension per stack allowed which has the connection to controlling devices. Zitieren
