ksm2353 Geschrieben April 29, 2013 at 16:45 Geschrieben April 29, 2013 at 16:45 When I try to install the brick viewer under windows 8 the drivers is not installed because the drives is not singed. What can I do to solve this issue. I've installed the latest versions of the viewer and deamon. Kasper Zitieren
photron Geschrieben April 30, 2013 at 08:41 Geschrieben April 30, 2013 at 08:41 On Windows 8 the Brick Daemon and Brick Viewer installers don't install any drivers, that's correct. There are two reasons for this: 1. The drivers aren't signed and Windows 8 doesn't allow to installed unsigned driver by default. 2. Windows 8 can auto detect a Brick and install it's own driver for it. You don't need the drivers that come with Brick Daemon and Brick Viewer on Windows 8. If you connect a Master Brick (with a version 2 firmware) to USB, it'll show up as "Master Brick" in the USB devices category in the device manager. Now brickd should be able to find it and a connected brickv should show it. If a Brick is in bootloader mode then Windows 8 will auto detect it as a serial port named "GPS Camera Detect". This serial port can then be selected in brickv for flashing. Doesn't it work for you as described? Zitieren
