Here's a first prototype of the shell bindings. They are written in Python for portability and use the argparse module for the command line handling.
Host and port default to localhost and 4223, they can be changed with the --host and --port option:
tinkerforge --host 192.168.178.42
Enumerate
It can enumerate connected devices:
$ tinkerforge enumerate
uid=68aT1f
connected-uid=0
position=0
hardware-version=1,0,0
firmware-version=2,0,6
device-identifier=13
uid=SCT31
connected-uid=68aT1f
position=a
hardware-version=1,1,0
firmware-version=2,0,0
device-identifier=216
The output is in <key>=<value> format can can then be processed further with xargs, awk, etc.
By default the bindings will wait 250ms for enumerate callbacks, this can be changed with the --duration option.
Functions
Calling the get-temperature function of a Temperature Bricklet with UID SCT31:
$ tinkerforge call temperature-bricklet --uid SCT31 get-temperature
temperature=2325
Callbacks
Setting the temperature callback period to 500ms:
$ tinkerforge call temperature-bricklet --uid SCT31 set-temperature-callback-period 500
and waiting for temperature callbacks
$ tinkerforge dispatch temperature-bricklet --uid SCT31 temperature
temperature=2418
temperature=2431
By default the bindings will dispatch callbacks forever, this can be changed with the --duration option.
Output Processing
There are two options for further output processing: --execute and --replace.
The --execute option takes a shell command. The bindings then append the output values to this command and execute it:
$ tinkerforge enumerate --execute echo
68aT1f 0 0 1,0,0 2,0,6 13 0
SCT31 68aT1f a 1,1,0 2,0,0 216 0
With the --replace option the bindings don't append the output values to the shell command but apply the Python string format function to the command string:
$ tinkerforge dispatch temperature-bricklet --uid SCT31 temperature --execute 'echo "scale=2; {temperature} / 100" | bc | xargs printf "`date`, the temperature is: %s °C\n"' --replace
Thu Apr 25 13:44:25 CEST 2013, the temperature is: 24.25 °C
This allows to use the key from the <key>=<value> output pairs as placeholders (wrapped in curly braces) in the shell command. The bindings replace them with the corresponding values before executing the shell command.
This two options are mainly intended for platforms such as Windows that don't have advanced shell commands (xargs, awk, etc) ready to use.
Bash Completion
For tab completion in bash the tinkerforge.bash_completion file has to be moved to /etc/bash_completion.d/ as tinkerforge and the tinkerforge script has to be in a location in PATH. Now tab completion should work.
tinkerforge
  • 3 months later...
