Brick Viewer - Connect, then nothing
RossMarsden
I have received my order today, thank you.
Master brick, IR distance measuring bricklet, and 4x20 LCD display.
I thought,  "Input and output; let's see what we can do!"
Very impressed with build quality, documentation, support, security of delivery, etc.
On WinXP, I have installed Brick daemon and it is listed with status "Started" in Services (under Administative Tools").
I have installed Brick Viewer, and started it.
Following instructions at http://www.tinkerforge.com/doc/Hardware/Bricks/Master_Brick.html#test-your-master-brick
"Connect the Brick to the PC over USB. You should see a tab named “Master Brick” in the Brick Viewer after you pressed “connect”. Select it."
There is a blue status light on Master Brick, and the Extension status LEDs did some sequential blinks up and down.
I have pressed "Connect" in Brick Viewer, but there is no tab named “Master Brick”.
I have host "localhost" and Port 4223.
IR Distance and 4x20 Display are not yet connected.
Is there a step I have missed?
Some ideas:
Do you have installed the drivers? Please check if the drivers are installed correctly.
(see http://www.tinkerforge.com/doc/Software/Brickd.html#windows-driver-installation)
Do you have restarted your PC after the Brick Daemon installation? If not please try it.
Also you can take a look into "Administrative Tools -> Events". If there are any problems they should be listed there.
Yes, restarted the PC after installing the daemon, and I installed the drivers OK.
I have just restarted again (after retiring to bed) to inform you of these which I had forgotten earlier.
We are working now!
Perhaps after a second restart (after drivers installed) it all comes together.
Thanks for your prompt reply.
Back to bed for me now. More tomorrow.
Cheers :-)
