JavaLaurence Geschrieben March 24, 2013 at 16:29 Geschrieben March 24, 2013 at 16:29 Hi guys, As you can see from the attached screenshot, I'm getting -78dB. This is for a setup where the AP is literally 1.5 meters away from the module. Both are separated by some (thick-ish) brick walls & ceiling. Does anyone have a signal strength that is worse than mine? Do you then suffer lots of TimeoutExceptions? Thx! Zitieren
