Monti Geschrieben March 21, 2013 at 17:39 Geschrieben March 21, 2013 at 17:39 Moin, ich versuche gerade folgendes Programm auszuführen: program project1; {$mode objfpc}{$H+} uses cthreads, Classes { you can add units after this }, SysUtils, IPConnection, BrickletLCD20x4,BrickletDistanceIR; type TCMD = class private ipcon: TIPConnection; lcd: TBrickletLCD20x4; dr: TBrickletDistanceIR; public procedure DistanceCB(sender: TBrickletDistanceIR; const distance: word); procedure Execute; end; const HOST = 'localhost'; PORT = 4223; UID = 'disp'; UIDB = 'dist'; var e: TCMD; procedure TCMD.DistanceCB(sender: TBrickletDistanceIR; const distance: word); begin if distance<1240 then begin //if (distance<701) and (distance >640) then WriteLn('Tuer Zu'); if (distance<500)and(distance>180) then begin lcd.WriteLine(0, 0, inttostr(distance)); lcd.writeline(1,0,datetimetostr(now)); end; WriteLn(inttostr(distance)); lcd.writeline(3,0,' '); lcd.WriteLine(3, 0, inttostr(distance)); end; end; procedure TCMD.Execute ; begin ipcon := TIPConnection.Create; lcd := TBrickletLCD20x4.Create(UID, ipcon); dr := TBrickletDistanceIR.Create(UIDB, ipcon); ipcon.Connect(HOST, PORT); dr.SetDistanceCallbackPeriod(150); lcd.BacklightOn; lcd.ClearDisplay; dr.OnDistance := {$ifdef FPC}@{$endif}DistanceCB; dr.SetDistanceCallbackThreshold('<', 20*10, 0); readln; ipcon.Destroy; end; begin e := TCMD.Create; e.Execute; e.Destroy; end. Beim ausführen über die Konsole kommt aber: pi@raspberrypi ~/Desktop/Lazarus/Tuer $ ./project1 An unhandled exception occurred at $00035650 : Exception : Could not resolve host: localhost $00035650 TIPCONNECTION__CONNECTUNLOCKED, line 475 of IPConnection.pas $000350FC TIPCONNECTION__CONNECT, line 289 of IPConnection.pas $0000871C TCMD__EXECUTE, line 55 of project1.lpr $00008854 main, line 66 of project1.lpr Der Master hängt direkt am Pi, Brickd ist installiert und ich kann mich von einem anderem Computer mit dem Master am Pi verbinden... Hat wer eine Idee, was da los ist? Monti Ist eventuell wichtig: Der Pi hat KEINE Internetverbindung, ich arbeite über statische IPs und einen LAN-Switch... Zitieren
borg Geschrieben March 21, 2013 at 17:59 Geschrieben March 21, 2013 at 17:59 Das ist ja ulkig, warum sollte er denn "localhost" nicht resolven können? Hast du schonmal probiert "127.0.0.1" anstatt "localhost" zu nehmen? Zitieren
Monti Geschrieben March 21, 2013 at 18:01 Autor Geschrieben March 21, 2013 at 18:01 Jop, die IP im Netzwerk hab ich auch schon getestet... Zitieren
remotecontrol Geschrieben March 21, 2013 at 19:49 Geschrieben March 21, 2013 at 19:49 Kurze Frage dazu: und ich kann mich von einem anderem Computer mit dem Master am Pi verbinden... D. h. über die externe IP des RasPI lässt sich der brickd ansprechen, von localhost aber nicht - korrekt? - Steht der localhost in der /etc/hosts des PI? - Ist das loopback-device gestartet? Der Befehl ifconfig müsste u.a. sowas ausgeben: lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 inet6 addr: ::1/128 Scope:Host UP LOOPBACK RUNNING MTU:16436 Metric:1 ... Zitieren
Monti Geschrieben March 21, 2013 at 20:13 Autor Geschrieben March 21, 2013 at 20:13 Zur externen IP: Ich kann von einem PC (nicht der Pi) mich per Brickv mit dem am Pi angeschlossenen Brick verbinden. Zur hosts Datei:localhost verweist auf 127.0.0.1, also alles in Ordnung. Und bei ifconfig stimmt auch alles... Zitieren
Monti Geschrieben March 21, 2013 at 21:06 Autor Geschrieben March 21, 2013 at 21:06 *Haut Kopf gegen die Wand* Mir fällt grad ein: Ich hab nicht die neuesten Bindings benutzt... Da hatten ja auch schon Andere Probleme unter Linux... Das könnte es sein, oder? (Testen mach ich morgen) Zitieren
Monti Geschrieben March 22, 2013 at 10:27 Autor Geschrieben March 22, 2013 at 10:27 Hab grad die Bindings aktualisiert: Jetzt geht alles... Zitieren
