[Brickv] Connect/Disconnect button disabling or deb ounce
I always use a Wacom Bamboo graphics tablet instead of a mouse. With some rare applications, like brickv, "mouse clicks" are interpreted too quickly by the application, leading to problems.
In the case of brickv, the Connect/Disconnect button sometimes behaves as if it gets two lightning-quick clicks, one after the other. I click Connect, the program tries to connect, and immediately tries to Disconnect.
I know this is behavior caused by the graphics tablet BUT 99% of programs do behave completely normally.
I would be grateful if TF could maybe disable the button while the connection attempt is pending, and re-enable it only when the connection is up?
Should be peanuts to implement..
