cl- Geschrieben August 21, 2024 at 11:48 Geschrieben August 21, 2024 at 11:48 Hi all, based on the specifications documented on your website, the Laser Range Finder Bricklet 2.0 should be able to measure distances lower than 5 cm. In my first tests, I couldn't measure distances lower than 5 cm though. Is this a technical limit? Cheers Claudio Technical specifications: Distance (Range, Resolution): 0-40m, 1cm Accuracy <5m: ±2.5cm (nonlinearity present below 1m) Zitieren
MatzeTF Geschrieben August 21, 2024 at 12:53 Geschrieben August 21, 2024 at 12:53 The datasheet only mentions a maximum range of 40m. The datasheet also mentions that at close range (< 1 m), “the beam diameter is about the size of the aperture (lens)”. At distances closer than 5 cm, the receiver is probably no longer able to see the laser beam projected in front of the transmitter. Zitieren
borg Geschrieben August 21, 2024 at 12:53 Geschrieben August 21, 2024 at 12:53 I think the resolution is 1cm, which does not mean that it can measure distances below 5cm. Here is the manufacturer datasheet of the laser range finder itself: https://raw.githubusercontent.com/Tinkerforge/laser-range-finder-v2-bricklet/master/datasheets/lidar-lite-v3.pdf It does unfortunately not explicitly specify a minimum distance. However, with a resolution of 1cm, and a accuracy of 2.5cm below 5m distance and "additional non-linearity below 1m" it sounds like 5cm for a low distance is reasonable. Zitieren
