dwisk Geschrieben July 27, 2024 at 12:32 Share Geschrieben July 27, 2024 at 12:32 Hi, after updating brickd to 2.4.6 it does not connect to the hat anymore on a Raspberry Pi 4 Model B Rev 1.5. (Hat firmware did not show any available updates before). I checked that SPI is enabled. 2024-07-27 13:21:51.398294 <I> <main_linux.c:385> Brick Daemon 2.4.6 started (architecture: arm64, pid: 2212, daemonized: 1) 2024-07-27 13:21:51.398344 <I> <main_linux.c:391> Running on Linux system (sysname: Linux, release: 6.1.21-v8+, version: #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023, machine: aarch64) 2024-07-27 13:21:51.409885 <I> <bricklet.c:274> Found supported HAT product_id 0x084e in device tree, using default HAT Brick config 2024-07-27 13:21:51.409905 <I> <bricklet.c:315> Found Bricklet port A (spidev: /dev/spidev0.0, driver: gpio, name: GPIO23, num: 23) 2024-07-27 13:21:51.409988 <I> <bricklet_stack_linux.c:87> Using spidev backend for Bricklets, because Raspberry Pi without BCM2835 detected 2024-07-27 13:21:51.411273 <I> <bricklet.c:315> Found Bricklet port B (spidev: /dev/spidev0.0, driver: gpio, name: GPIO22, num: 22) 2024-07-27 13:21:51.412419 <I> <bricklet.c:315> Found Bricklet port C (spidev: /dev/spidev0.0, driver: gpio, name: GPIO25, num: 25) 2024-07-27 13:21:51.413494 <I> <bricklet.c:315> Found Bricklet port D (spidev: /dev/spidev0.0, driver: gpio, name: GPIO26, num: 26) 2024-07-27 13:21:51.414650 <I> <bricklet.c:315> Found Bricklet port E (spidev: /dev/spidev0.0, driver: gpio, name: GPIO27, num: 27) 2024-07-27 13:21:51.415818 <I> <bricklet.c:315> Found Bricklet port F (spidev: /dev/spidev0.0, driver: gpio, name: GPIO24, num: 24) 2024-07-27 13:21:51.416855 <I> <bricklet.c:315> Found Bricklet port G (spidev: /dev/spidev0.0, driver: gpio, name: GPIO7, num: 7) 2024-07-27 13:21:51.417584 <E> <bricklet_stack_linux_spidev.c:263> Could not find line GPIO7 2024-07-27 13:21:52.417727 <I> <main_linux.c:579> Brick Daemon 2.4.6 stopped Any ideas on what went wrong? Also downgrading to brickd 2.4.3 seems not available with aptget. There it did connect. Regards Amely Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
MatzeTF Geschrieben July 27, 2024 at 22:04 Share Geschrieben July 27, 2024 at 22:04 This is a known problem that will be fixed with 2.4.7. Were you able to downgrade to 2.4.3? If not, you can download older versions from here. 1 Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
Superp Geschrieben July 28, 2024 at 08:43 Share Geschrieben July 28, 2024 at 08:43 See the thread Brick Daemon 2.4.6 not working for a discussion of the problem instructions for downgrading to brickd 2.4.5 (fix) a preview of brickd 2.4.7 (alternate fix) Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
MatzeTF Geschrieben July 28, 2024 at 10:24 Share Geschrieben July 28, 2024 at 10:24 Please note that the brickd 2.4.7 preview in that thread is for armhf, not arm64, which is what the OP is running. Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
photron Geschrieben July 29, 2024 at 10:57 Share Geschrieben July 29, 2024 at 10:57 brickd 2.4.7 is now available from our APT server. Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
