Superp Geschrieben July 18, 2024 at 21:21 Geschrieben July 18, 2024 at 21:21 Hello, I have upgraded four of our systems from brickd 2.4.5 -> 2.4.6, and brickd stopped responding on all of them: <I> <main_linux.c:385> Brick Daemon 2.4.6 started (architecture: arm, pid: 25228, daemonized: 1) <I> <main_linux.c:391> Running on Linux system (sysname: Linux, release: 6.1.21-v7+, version: #1642 SMP Mon Apr 3 17:20:52 BST 2023, machine: armv7l) <I> <bricklet.c:274> Found supported HAT product_id 0x084e in device tree, using default HAT Brick config <I> <bricklet.c:315> Found Bricklet port A (spidev: /dev/spidev0.0, driver: gpio, name: GPIO23, num: 23) <I> <bricklet_stack_linux.c:87> Using spidev backend for Bricklets, because Raspberry Pi without BCM2835 detected <I> <bricklet.c:315> Found Bricklet port B (spidev: /dev/spidev0.0, driver: gpio, name: GPIO22, num: 22) <I> <bricklet.c:315> Found Bricklet port C (spidev: /dev/spidev0.0, driver: gpio, name: GPIO25, num: 25) <I> <bricklet.c:315> Found Bricklet port D (spidev: /dev/spidev0.0, driver: gpio, name: GPIO26, num: 26) <I> <bricklet.c:315> Found Bricklet port E (spidev: /dev/spidev0.0, driver: gpio, name: GPIO27, num: 27) <I> <bricklet.c:315> Found Bricklet port F (spidev: /dev/spidev0.0, driver: gpio, name: GPIO24, num: 24) <I> <bricklet.c:315> Found Bricklet port G (spidev: /dev/spidev0.0, driver: gpio, name: GPIO7, num: 7) <E> <bricklet_stack_linux_spidev.c:263> Could not find line GPIO7 <I> <main_linux.c:579> Brick Daemon 2.4.6 stopped These systems are all Raspberry Pi 3 Model A Plus Rev 1.0 with a HAT Brick. Downgrading to brickd 2.4.5 fixed the problem on all four systems, for now. Is this a known issue? Zitieren
MatzeTF Geschrieben July 19, 2024 at 00:09 Geschrieben July 19, 2024 at 00:09 Yes, this is a known issue that we recently discovered. Please keep using brickd 2.4.5 for RPi 1-4 until we can fix the issue. 1 Zitieren
zbindenp Geschrieben July 19, 2024 at 18:55 Geschrieben July 19, 2024 at 18:55 (bearbeitet) Hello all Thank you for the information. I have the same problem and like to downgrade to 2.4.5, but get an error when trying to do that: sudo apt install brickd=2.4.5 Reading package lists... Done Building dependency tree... Done Reading state information... Done E: Version '2.4.5' for 'brickd' was not found How can i fix that? Ok, found it. How I did it (perhaps would help others): wget https://download.tinkerforge.com/tools/brickd/linux/brickd-2.4.5_armhf.deb sudo dpkg --install brickd-2.4.5_armhf.deb rm brickd-2.4.5_armhf.deb bearbeitet July 19, 2024 at 19:15 von zbindenp Found a workaround 1 Zitieren
Superp Geschrieben July 19, 2024 at 21:08 Autor Geschrieben July 19, 2024 at 21:08 @zbindenp That is exactly what I did. Thanks for sharing the write up. This would be an excellent opportunity for reviving the near-dead blog. Write two lines informing us about the (avoidable) problem and the fix. RSS is our friend. Zitieren
photron Geschrieben July 24, 2024 at 14:32 Geschrieben July 24, 2024 at 14:32 Please try the attached brickd version: sudo dpkg -i brickd_2.4.7_armhf.deb brickd_2.4.7_armhf.debFetching info... brickd_2.4.7_arm64.debFetching info... Zitieren
Superp Geschrieben July 25, 2024 at 07:52 Autor Geschrieben July 25, 2024 at 07:52 It works here. Zitieren
zbindenp Geschrieben July 25, 2024 at 17:41 Geschrieben July 25, 2024 at 17:41 Works here also. RasperryPi Zero with RaspberryPiOS bullseye Zitieren
photron Geschrieben July 29, 2024 at 10:58 Geschrieben July 29, 2024 at 10:58 brickd 2.4.7 is now available from our APT server. 1 Zitieren
nineax Geschrieben September 17, 2024 at 14:13 Geschrieben September 17, 2024 at 14:13 (bearbeitet) I get the message “Brick Daemon 2.4.7 stopped” I'm working on a Rasbarry Py5 and have already tested version 2.4.6. Same error on this version. Can you maybe help me? PS: I tried out on Ubuntu, do I need to switch to pyos? bearbeitet September 17, 2024 at 14:23 von nineax Zitieren
photron Geschrieben September 17, 2024 at 16:36 Geschrieben September 17, 2024 at 16:36 Am 17.9.2024 um 14:13 schrieb nineax: I get the message “Brick Daemon 2.4.7 stopped” Expand Where do you get this message? Could you please show the full output of the command "systemctl status brickd", the command "uname -a", the command "gpioinfo" and attach the /var/log/brickd.log file from your Raspberry Pi? Zitieren
nineax Geschrieben September 18, 2024 at 09:30 Geschrieben September 18, 2024 at 09:30 I switched to Pyos and everything works now. Anyway, thanks for helping. Zitieren
