yvo Geschrieben July 1, 2024 at 15:06 Share Geschrieben July 1, 2024 at 15:06 Dear list I followed the installation-instruction as given on the website for brickd and brickv. After the installation of both, I tried to connect to the attached HAT (version 1.9) using brickv. The brickv started without any problems. But brickv wasn't able to connect with localhost: An connection error occurred. Please check host, check port and ensure that Brick Daemon is running: [Errno 111] Connection refused Trying to start brickd manually, I got the following information: 2024-07-01 16:50:12.151642 <I> <main_linux.c:369> Brick Daemon 2.4.5 started (pid: 2989, daemonized: 0) 2024-07-01 16:50:12.151654 <I> <main_linux.c:375> Running on Linux system (sysname: Linux, release: 6.6.31+rpt-rpi-v8, version: #1 SMP PREEMPT Debian 1:6.6.31-1+rpt1 (2024-05-29), machine: aarch64) libusb: warning [libusb_init] installing new context as implicit default 2024-07-01 16:50:12.155327 <I> <bricklet.c:304> Found supported HAT product_id 0x084e in device tree, using default HAT Brick config 2024-07-01 16:50:12.155332 <I> <bricklet.c:345> Found Bricklet port A (spidev: /dev/spidev0.0, driver: gpio, name: gpio422, num: 422) 2024-07-01 16:50:12.155355 <I> <bricklet_stack_linux.c:87> Using spidev backend for Bricklets (unsupported suffix 5 after 'Raspberry Pi' in /proc/device-tree/model) 2024-07-01 16:50:12.155383 <E> <gpio_sysfs.c:77> Could not write to '/sys/class/gpio/export' to export GPIO 422: EINVAL (22) 2024-07-01 16:50:12.155386 <E> <bricklet_stack_linux_spidev.c:78> Could not export gpio422: EINVAL (22) 2024-07-01 16:50:12.155505 <I> <main_linux.c:563> Brick Daemon 2.4.5 stopped Question: Do I have to install a brickd-version for 64bit manually? And if yes, which version would that be? Or do you have any other ideas and recommendations? Browsing the forum, I found several issues like the current one: 12334-error-installing-brickd But somehow, I didn't understand the solution. Looking forward to any suggestions. Cheers, Yvo Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
photron Geschrieben July 1, 2024 at 16:04 Share Geschrieben July 1, 2024 at 16:04 Currently there is a problem with Raspberry Pi 5 and more recent Linux kernel versions. Please try the attached brickd version. There will be a new release shortly. Sorry, for the long time it takes us to fix this problem. Edit: Attachment deleted. Brick Daemon 2.4.6 has been released. Please install the official release instead. Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
yvo Geschrieben July 3, 2024 at 07:43 Autor Share Geschrieben July 3, 2024 at 07:43 Dear photron Great, I just updated brickd using the update-tool of the Raspberry and it works. Thank you very much for all your work. Cheers, Yvo Zitieren Link zu diesem Kommentar Share on other sites More sharing options...
