Superp Geschrieben April 5, 2024 at 20:30 Geschrieben April 5, 2024 at 20:30 Hello, The LED Strip Bricklet 2.0 can be connected to the DC power supply line for the LEDs it controls. What is the maximum DC voltage the Bricklet can safely handle? I can't find this in the docs. Zitieren
MatzeTF Geschrieben April 6, 2024 at 16:35 Geschrieben April 6, 2024 at 16:35 30 V should be safe. The absolute maximum is probably about 36 V. The + pins are only used for voltage monitoring and the LED strip should not draw its power via the bricklet. If you need more than 30 V, just don’t connect any of the + pins. The voltage monitoring might actually saturate before reaching 36 V. If you want to know how high it can go, just keep an eye on the reported voltage while raising the input voltage until it saturates. 1 Zitieren
