xsherlock Geschrieben February 15, 2024 at 12:22 Geschrieben February 15, 2024 at 12:22 I just updated to the latest firmware and I still see that when NFC reader reads the tag from the smartphone it does change all the time. And it also shows only 8 bytes of the address and not all 16 as with the supplied cards. Is there really no way to reliably identify the user by the Android smartphone? I think that such a Funcionality is super important. Zitieren
MatzeTF Geschrieben February 15, 2024 at 14:21 Geschrieben February 15, 2024 at 14:21 Please let the NFC reader read the tag from the smartphone and then download a debug log from the Warp2 and upload it here. Zitieren
rtrbt Geschrieben February 16, 2024 at 07:56 Geschrieben February 16, 2024 at 07:56 This won't work. Android smartphones periodically change the NFC tag ID. The only way to change this (as far as I know) is to use some kind of NFC card emulation app that (depending on your smartphone) will only work if you root your phone. See for example here: https://stackoverflow.com/questions/19764476/host-based-card-emulation-with-fixed-card-id We've thought about not using a tag's ID but instead the first payload page (see here: https://github.com/Tinkerforge/esp32-firmware/issues/90) but nobody had the time to implement this yet. Zitieren
xsherlock Geschrieben February 16, 2024 at 14:40 Autor Geschrieben February 16, 2024 at 14:40 It works in the ENEL charging platform here in italy where the charger will log you in even without the enel app installed. I did setup that once and then reflashed a phone and it still authorizes me. Looking forward, I have this uni campus project where a lot of chargers has to be installed and distributing people cards would be a PITA. Zitieren
