elektron Geschrieben November 1, 2023 at 08:58 Geschrieben November 1, 2023 at 08:58 Hallo zusammen, seit dem Update meiner Warp2 auf die 2.1.5 sehe ich zwei Effekte die ich nicht so recht verstehe. 1.) wir mir auf beiden Wallboxen angezeigt, dass das Laden durch das Lastmanagement blockiert ist. Erlaubter Ladestrom: „Blockiert durch Lastmanagement“. 2.) zusätzlich habe ich im Log Meldungen über unbekannte Topics… 7,172 This is Wallbox1 (warp2-XY4), a WARP2 Charger Smart 22kW 7,661 CM failed to send command: Host is unreachable (118) 8,349 Wifi connected to enterprise.XSC.tv, BSSID 08:BE:AC:11:22:33 8,371 Wifi got IP address: 192.168.2.198/24. Own MAC address: A8:03:2A:44:55:66 2023-11-01 09:49:11,804 NTP synchronized at 21,606! 2023-11-01 09:49:17,348 MQTT: Connected to broker. 2023-11-01 09:49:18,597 MQTT: Received message on unknown topic 'evse/energy_meter_values' (data_len=116) 2023-11-01 09:49:18,607 MQTT: Received message on unknown topic 'evse/control_pilot_configuration' (data_len=19) 2023-11-01 09:49:18,683 MQTT: Received message on unknown topic 'evse/dc_fault_current_state' (data_len=11) 2023-11-01 09:49:18,703 MQTT: Received message on unknown topic 'evse/max_charging_current' (data_len=126) 2023-11-01 09:49:18,733 MQTT: Received message on unknown topic 'evse/energy_meter_state' (data_len=50) 2023-11-01 09:49:18,738 MQTT: Received message on unknown topic 'version' (data_len=55) 2023-11-01 09:49:18,756 MQTT: Received message on unknown topic 'modules' (data_len=247) 2023-11-01 09:49:18,766 MQTT: Received message on unknown topic 'evse/control_pilot_connected' (data_len=18) 2023-11-01 09:49:18,776 MQTT: Received message on unknown topic 'meter/detailed_values' (data_len=2) 2023-11-01 09:49:18,805 MQTT: Received message on unknown topic 'evse/managed' (data_len=17) 2023-11-01 09:49:18,810 MQTT: Received message on unknown topic 'authentication/config' (data_len=51) 2023-11-01 09:49:18,847 MQTT: Received message on unknown topic 'debug/state' (data_len=67) 2023-11-01 09:53:51,922 Wrote last uptime to flash Ich habe noch nicht probiert zu laden, war nur in meiner Erinnerung vorher nich so… vielen Dank und Grüße Michael Zitieren
rtrbt Geschrieben November 2, 2023 at 08:36 Geschrieben November 2, 2023 at 08:36 On 11/1/2023 at 9:58 AM, elektron said: 1.) wir mir auf beiden Wallboxen angezeigt, dass das Laden durch das Lastmanagement blockiert ist. Erlaubter Ladestrom: „Blockiert durch Lastmanagement“. Solange kein Auto angeschlossen ist, ist das korrekt. Das Lastmanagement teilt einer Wallbox erst Strom zu, wenn sie den auch braucht. On 11/1/2023 at 9:58 AM, elektron said: 2.) zusätzlich habe ich im Log Meldungen über unbekannte Topics… Die traditionelle erste Frage: Benutzt du ioBroker? Dessen MQTT-Broker ist nicht standardkonform und macht gerne mal Probleme. Siehe z.B. hier: Zitieren
elektron Geschrieben November 4, 2023 at 09:28 Autor Geschrieben November 4, 2023 at 09:28 Hallo RTRBT, vielen Dank für die schnelle Antwort. Dann bin ich ja entspannt. Wegen der MQTT-Fehlermeldungen. Ich nutze den in FHEM eingebauten MQTT-Server. Also keinen separaten Broker wie Mosqitto. Ich habe da mal in der Dokumentation gelesen und verstehe es aktuell so, dass das auch Nachrichten die mit retain markiert sind (im Default) nich gespeichert werden. ich schaue es mir aber mal mit einem „externen“ MQTT Client an, was beim Verbinden passiert bzw. Ob die entsprechenden Topics dann „feuern“… viele Grüße Michael Zitieren
MatzeTF Geschrieben November 6, 2023 at 10:37 Geschrieben November 6, 2023 at 10:37 Wenn du MQTT in der Konfiguration schon lange am Laufen hast, können das auch obsolete alte Nachrichten sein, die immer noch auf dem MQTT-Server vorgehalten werden. Hat der Server eine Option, um vorgehaltene Nachrichten mit „retain“-Flag zu löschen? Alternativ kannst du die Nachrichten auch von Hand mit einem Kommandozeilen-MQTT-Client löschen. Üblicherweise reicht es dazu, wenn du eine leere Nachricht mit „retain“-Flag an das entsprechende Topic sendest, also z. B. an warp2/XY4/modules. Zitieren
