greyghost Geschrieben October 11, 2023 at 10:05 Geschrieben October 11, 2023 at 10:05 Hallo, ich kann von keinem bricklet mit der shell-api das get-identify Kommando erfolgreich ausführen. Es gibt immer Fehlermeldungen wie ~$ tinkerforge --host tf1 call industrial-digital-out-4-v2-bricklet Tm6 get-identity Traceback (most recent call last): File "/usr/bin/tinkerforge", line 38379, in <module> main() File "/usr/bin/tinkerforge", line 38364, in main parse(ctx, sys.argv[1:]) File "/usr/bin/tinkerforge", line 38352, in parse commands[args.command](ctx, args.args) File "/usr/bin/tinkerforge", line 37948, in command_call call_devices[args.device](ctx, args.args) File "/usr/bin/tinkerforge", line 15318, in call_industrial_digital_out_4_v2_bricklet call_generic(ctx, 'industrial-digital-out-4-v2-bricklet', functions, argv) File "/usr/bin/tinkerforge", line 254, in call_generic functions[args.function](ctx, args.args) File "/usr/bin/tinkerforge", line 15292, in get_identity common_get_identity(ctx, prog_prefix, IndustrialDigitalOut4V2Bricklet, argv) File "/usr/bin/tinkerforge", line 839, in common_get_identity device_call(ctx, device_class, 255, (), '', '8s 8s c 3B 3B H', args.execute, False, TypeError: device_call() missing 1 required positional argument: 'symbols' Mache ich irgendwas falsch? Andere Kommandos funktionieren soweit problemlos. Zitieren
photron Geschrieben October 11, 2023 at 10:50 Geschrieben October 11, 2023 at 10:50 Sorry, there was a bug in this call. Please try the attached version. tinkerforge_shell_bindings_2_1_33_beta1.zip 1 Zitieren
greyghost Geschrieben October 12, 2023 at 06:42 Autor Geschrieben October 12, 2023 at 06:42 The command works fine in the beta version, thanks! Zitieren
