lemmi25 Geschrieben July 6, 2023 at 15:19 Geschrieben July 6, 2023 at 15:19 Hi, I am using the TinkerForge RS232 V2 Module and want to read sensor data. This is my code #!/usr/bin/env python # -*- coding: utf-8 -*- # For this example connect the RX1 and TX pin to receive the send message HOST = "localhost" PORT = 4223 UID = "XXXX" # Change XYZ to the UID of your RS232 Bricklet 2.0 from tinkerforge.ip_connection import IPConnection from tinkerforge.bricklet_rs232_v2 import BrickletRS232V2 import time # Callback function for read callback def rs232_data_received(data): test = ''.join(data) print(test) if __name__ == "__main__": ipcon = IPConnection() # Create IP connection rs232 = BrickletRS232V2(UID, ipcon) # Create device object ipcon.connect(HOST, PORT) # Connect to brickd rs232.set_configuration(baudrate=9600, parity=BrickletRS232V2.PARITY_NONE, stopbits=BrickletRS232V2.STOPBITS_1, wordlength=BrickletRS232V2.WORDLENGTH_8, flowcontrol=BrickletRS232V2.FLOWCONTROL_OFF) # Don't use device before ipcon is connected print(rs232.get_chip_temperature()) # Register read callback to function cb_read rs232.register_callback(rs232.CALLBACK_READ, rs232_data_received) # Enable read callback rs232.enable_read_callback() input("Press key to exit\n") # Use raw_input() in Python 2 ipcon.disconnect() The problem is, when I get the data output I only see unusual characters like this: [ ý ¿ ¿ å ë [ ý å ë [ ý When I use a FTDI Chip I can read the correct output (using pyserial). I also attached a LogicAnalyzer and the data shows fine. So I think it is a problem of converting the Data (Baudrate is correct). Since I do not now what in the middle "layer" of TinkerForge is happening with the data, can someone please help me how to convert the data into correct ascii Numbers? Many thanks Zitieren
photron Geschrieben July 6, 2023 at 15:50 Geschrieben July 6, 2023 at 15:50 Try replacing this test = ''.join(data) with this test = [hex(ord(x)) for x in data] This will give you a list of hex numbers. Zitieren
lemmi25 Geschrieben July 7, 2023 at 09:29 Autor Geschrieben July 7, 2023 at 09:29 Hey, thanks for the fast reply. Getting the hex numbers is not my Problem. The character (when I convert the hex numbers) just make no sense. They should be numbers and or normal characters. Here is the datasheet from the sensor. https://www.digikey.de/de/products/detail/gas-sensing-solutions-ltd/EXPLORIR-M-20/9952879 Zitieren
photron Geschrieben July 7, 2023 at 09:45 Geschrieben July 7, 2023 at 09:45 How did you conect the sensor to the Bricklet? You have to connect it to the pin header which expects 3.3V TTL signals. You cannot connect it to the D-Sub 9 connector nor the terminal block, both expect RS232 voltage levels. I think you also need to power the sensor with 3.3V to make it output 3.3V TTL signals. Zitieren
lemmi25 Geschrieben July 7, 2023 at 10:55 Autor Geschrieben July 7, 2023 at 10:55 okay many thanks, that solved it ;) Zitieren
