HAT-Brick on Rock Pi 4
FATTOMCAT
Ich habe einen Rock Pi 4 als ersatz für den Rapberry Pi gekauft.
Out of the box funktioniert der HAT nicht. Gibt es eine Möglichkeit das zu ändern?
Wenn ich den bickd starte erhalte ich diesen output:
2023-03-27 15:21:03.317550 <E> <bricklet_stack_linux_spidev.c:117> Could not configure SPI mode: EINVAL (22)
[timestamp] [threadID] facility level [function call] <message>
[ 0.000015] [00000640] libusb: debug [libusb_init] created default context
[ 0.000200] [00000640] libusb: debug [libusb_init] libusb v1.0.21.11156
[ 0.000370] [00000640] libusb: debug [find_usbfs_path] found usbfs at /dev/bus/usb
[ 0.000464] [00000640] libusb: debug [op_init] bulk continuation flag supported
[ 0.000524] [00000640] libusb: debug [op_init] zero length packet flag supported
[ 0.000635] [00000640] libusb: debug [op_init] sysfs can relate devices
[ 0.000687] [00000640] libusb: debug [op_init] sysfs has complete descriptors
2023-03-27 15:21:03.298263 <I> <main_linux.c:369> Brick Daemon 2.4.4 started (pid: 1600, daemonized: 0)
2023-03-27 15:21:03.298329 <I> <main_linux.c:375> Running on Linux system (sysname: Linux, release: 4.4.154-90-rockchip-ga14f6502e045, version: #22 SMP Tue Jul 30 10:32:28 UTC 2019, machine: aarch64)
2023-03-27 15:21:03.298350 <D> <main_linux.c:384> Using config file: /etc/brickd.conf
[ 0.003458] [00000642] libusb: debug [linux_udev_event_thread_main] udev event thread entering.
2023-03-27 15:21:03.298357 <D> <main_linux.c:390> Using PID file: /var/run/brickd.pid
2023-03-27 15:21:03.298362 <W> <main_linux.c:394> Warning(s) in config file '/etc/brickd.conf', run with --check-config option for details
2023-03-27 15:21:03.298370 <D> <event.c:60> Initializing event subsystem
2023-03-27 15:21:03.298471 <D> <event|event.c:270> Added generic event source (handle: 5, name: event-stop, events: 0x0001) at index 0
2023-03-27 15:21:03.298518 <D> <event|event.c:270> Added generic event source (handle: 7, name: signal, events: 0x0001) at index 1
2023-03-27 15:21:03.298552 <D> <hardware.c:39> Initializing hardware subsystem
2023-03-27 15:21:03.298562 <D> <usb.c:296> Initializing USB subsystem
2023-03-27 15:21:03.298595 <D> <event|event.c:270> Added generic event source (handle: 9, name: usb-hotplug, events: 0x0001) at index 2
[ 0.011232] [00000640] libusb: debug [linux_get_device_address] getting address for device: usb1 detached: 0
[ 0.011294] [00000640] libusb: debug [linux_get_device_address] scan usb1
[ 0.011554] [00000640] libusb: debug [linux_get_device_address] bus=1 dev=1
[ 0.011596] [00000640] libusb: debug [linux_enumerate_device] busnum 1 devaddr 1 session_id 257
[ 0.011622] [00000640] libusb: debug [linux_enumerate_device] allocating new device for 1/1 (session 257)
[ 0.012189] [00000640] libusb: debug [linux_get_device_address] getting address for device: usb3 detached: 0
[ 0.012233] [00000640] libusb: debug [linux_get_device_address] scan usb3
[ 0.012436] [00000640] libusb: debug [linux_get_device_address] bus=3 dev=1
[ 0.012474] [00000640] libusb: debug [linux_enumerate_device] busnum 3 devaddr 1 session_id 769
[ 0.012498] [00000640] libusb: debug [linux_enumerate_device] allocating new device for 3/1 (session 769)
[ 0.013000] [00000640] libusb: debug [linux_get_device_address] getting address for device: usb2 detached: 0
[ 0.013042] [00000640] libusb: debug [linux_get_device_address] scan usb2
[ 0.013252] [00000640] libusb: debug [linux_get_device_address] bus=2 dev=1
[ 0.013339] [00000640] libusb: debug [linux_enumerate_device] busnum 2 devaddr 1 session_id 513
[ 0.013363] [00000640] libusb: debug [linux_enumerate_device] allocating new device for 2/1 (session 513)
[ 0.013856] [00000640] libusb: debug [linux_get_device_address] getting address for device: usb4 detached: 0
[ 0.013934] [00000640] libusb: debug [linux_get_device_address] scan usb4
[ 0.014133] [00000640] libusb: debug [linux_get_device_address] bus=4 dev=1
[ 0.014204] [00000640] libusb: debug [linux_enumerate_device] busnum 4 devaddr 1 session_id 1025
[ 0.014227] [00000640] libusb: debug [linux_enumerate_device] allocating new device for 4/1 (session 1025)
[ 0.014761] [00000640] libusb: debug [linux_get_device_address] getting address for device: usb5 detached: 0
[ 0.014835] [00000640] libusb: debug [linux_get_device_address] scan usb5
[ 0.015044] [00000640] libusb: debug [linux_get_device_address] bus=5 dev=1
[ 0.015155] [00000640] libusb: debug [linux_enumerate_device] busnum 5 devaddr 1 session_id 1281
[ 0.015182] [00000640] libusb: debug [linux_enumerate_device] allocating new device for 5/1 (session 1281)
[ 0.015764] [00000640] libusb: debug [linux_get_device_address] getting address for device: usb6 detached: 0
[ 0.015828] [00000640] libusb: debug [linux_get_device_address] scan usb6
[ 0.016034] [00000640] libusb: debug [linux_get_device_address] bus=6 dev=1
[ 0.016107] [00000640] libusb: debug [linux_enumerate_device] busnum 6 devaddr 1 session_id 1537
[ 0.016167] [00000640] libusb: debug [linux_enumerate_device] allocating new device for 6/1 (session 1537)
[ 0.016449] [00000640] libusb: debug [usbi_add_pollfd] add fd 14 events 1
[ 0.016556] [00000640] libusb: debug [usbi_io_init] using timerfd for timeouts
[ 0.016581] [00000640] libusb: debug [usbi_add_pollfd] add fd 16 events 1
[ 0.016807] [00000640] libusb: debug [libusb_get_device_list]
[ 0.016915] [00000640] libusb: debug [libusb_get_device_descriptor]
[ 0.017001] [00000640] libusb: debug [libusb_get_device_descriptor]
[ 0.017077] [00000640] libusb: debug [libusb_get_device_descriptor]
[ 0.017118] [00000640] libusb: debug [libusb_get_device_descriptor]
[ 0.017162] [00000640] libusb: debug [libusb_get_device_descriptor]
[ 0.017204] [00000640] libusb: debug [libusb_get_device_descriptor]
2023-03-27 15:21:03.315366 <D> <event|event.c:270> Added USB event source (handle: 14, name: usb-poll, events: 0x0001) at index 3
2023-03-27 15:21:03.315431 <D> <event|event.c:270> Added USB event source (handle: 16, name: usb-poll, events: 0x0001) at index 4
2023-03-27 15:21:03.315455 <D> <usb.c:413> Starting initial USB device scan
2023-03-27 15:21:03.315460 <D> <usb.c:492> Looking for added/removed USB devices
2023-03-27 15:21:03.315562 <D> <usb.c:186> Found 6 USB device(s)
2023-03-27 15:21:03.315917 <D> <network.c:177> Initializing network subsystem
2023-03-27 15:21:03.315946 <D> <socket.c:164> Opening server socket(s) for address '0.0.0.0' on port 4223
2023-03-27 15:21:03.316115 <D> <socket.c:264> Started listening to '0.0.0.0' (IPv4) resolved from '0.0.0.0' on port 4223
2023-03-27 15:21:03.316141 <D> <event|event.c:270> Added generic event source (handle: 17, name: server, events: 0x0001) at index 5
2023-03-27 15:21:03.316155 <D> <mesh.c:53> Initializing mesh subsystem
2023-03-27 15:21:03.316164 <D> <mesh.c:156> Mesh gateway is enabled
2023-03-27 15:21:03.316168 <D> <socket.c:164> Opening server socket(s) for address '0.0.0.0' on port 4240
2023-03-27 15:21:03.316221 <D> <socket.c:264> Started listening to '0.0.0.0' (IPv4) resolved from '0.0.0.0' on port 4240
2023-03-27 15:21:03.316237 <D> <event|event.c:270> Added generic event source (handle: 18, name: mesh-server, events: 0x0001) at index 6
2023-03-27 15:21:03.316331 <D> <bricklet.c:260> No HAT product_id file in device tree, not using default HAT Brick config
2023-03-27 15:21:03.316382 <D> <bricklet.c:260> No HAT product_id file in device tree, not using default HAT Zero Brick config
2023-03-27 15:21:03.316430 <D> <bricklet.c:260> No HAT product_id file in device tree, not using default HAT WARP Energy Manager Brick config
2023-03-27 15:21:03.316436 <D> <bricklet.c:465> Found no supported HAT product_id in device tree, checking bricklet.* section in config file instead
2023-03-27 15:21:03.316469 <I> <bricklet.c:521> Using bricklet.* section in config file
2023-03-27 15:21:03.316473 <I> <bricklet.c:530> Found Bricklet port A (spidev: /dev/spidev32766.0, driver: gpio, name: gpio23, num: 23)
2023-03-27 15:21:03.316484 <D> <bricklet_stack.c:806> Initializing Bricklet stack subsystem for port A
2023-03-27 15:21:03.316538 <D> <event|event.c:270> Added generic event source (handle: 19, name: bricklet-stack-notification, events: 0x0001) at index 7
2023-03-27 15:21:03.316640 <I> <bricklet_stack_linux.c:132> Using spidev backend for Bricklets (no 'Raspberry Pi' prefix in /proc/device-tree/model)
2023-03-27 15:21:03.317623 <D> <event|event.c:408> Marked generic event source (handle: 19, name: bricklet-stack-notification, events: 0x0001) as removed at index 7
2023-03-27 15:21:03.317649 <D> <mesh.c:74> Shutting down mesh subsystem
2023-03-27 15:21:03.317660 <D> <event|event.c:408> Marked generic event source (handle: 18, name: mesh-server, events: 0x0001) as removed at index 6
2023-03-27 15:21:03.317715 <D> <network.c:275> Shutting down network subsystem
2023-03-27 15:21:03.317728 <D> <event|event.c:408> Marked generic event source (handle: 17, name: server, events: 0x0001) as removed at index 5
2023-03-27 15:21:03.317877 <D> <usb.c:451> Shutting down USB subsystem
2023-03-27 15:21:03.317896 <D> <event|event.c:408> Marked USB event source (handle: 14, name: usb-poll, events: 0x0001) as removed at index 3
2023-03-27 15:21:03.317912 <D> <event|event.c:408> Marked USB event source (handle: 16, name: usb-poll, events: 0x0001) as removed at index 4
[ 0.019270] [00000640] libusb: debug [libusb_exit]
[ 0.020781] [00000640] libusb: debug [libusb_exit] destroying default context
[ 0.020844] [00000640] libusb: debug [libusb_handle_events_timeout_completed] doing our own event handling
[ 0.020869] [00000640] libusb: debug [handle_events] poll fds modified, reallocating
[ 0.020904] [00000640] libusb: debug [handle_events] poll() 2 fds with timeout in 0ms
[ 0.021059] [00000640] libusb: debug [handle_events] poll() returned 1
[ 0.021073] [00000640] libusb: debug [handle_events] caught a fish on the event pipe
[ 0.021086] [00000640] libusb: debug [handle_events] hotplug message received
[ 0.021100] [00000640] libusb: debug [handle_events] poll() 2 fds with timeout in 0ms
[ 0.021113] [00000640] libusb: debug [handle_events] poll() returned 1
[ 0.021124] [00000640] libusb: debug [handle_events] caught a fish on the event pipe
[ 0.021166] [00000640] libusb: debug [handle_events] hotplug message received
[ 0.021194] [00000640] libusb: debug [handle_events] poll() 2 fds with timeout in 0ms
[ 0.021209] [00000640] libusb: debug [handle_events] poll() returned 0
[ 0.021232] [00000640] libusb: debug [libusb_unref_device] destroy device 6.1
[ 0.021252] [00000640] libusb: debug [libusb_unref_device] destroy device 5.1
[ 0.021267] [00000640] libusb: debug [libusb_unref_device] destroy device 4.1
[ 0.021307] [00000640] libusb: debug [libusb_unref_device] destroy device 2.1
[ 0.021321] [00000640] libusb: debug [libusb_unref_device] destroy device 3.1
[ 0.021335] [00000640] libusb: debug [libusb_unref_device] destroy device 1.1
[ 0.021351] [00000640] libusb: debug [usbi_remove_pollfd] remove fd 14
[ 0.021405] [00000640] libusb: debug [usbi_remove_pollfd] remove fd 16
[ 0.021527] [00000642] libusb: debug [linux_udev_event_thread_main] udev event thread exiting
2023-03-27 15:21:03.320498 <D> <event|event.c:408> Marked generic event source (handle: 9, name: usb-hotplug, events: 0x0001) as removed at index 2
2023-03-27 15:21:03.320547 <D> <hardware.c:53> Shutting down hardware subsystem
2023-03-27 15:21:03.320565 <D> <event|event.c:408> Marked generic event source (handle: 7, name: signal, events: 0x0001) as removed at index 1
2023-03-27 15:21:03.320586 <D> <event.c:124> Shutting down event subsystem
2023-03-27 15:21:03.320592 <D> <event|event.c:408> Marked generic event source (handle: 5, name: event-stop, events: 0x0001) as removed at index 0
2023-03-27 15:21:03.320618 <D> <event|event.c:427> Removed generic event source (handle: 19, name: bricklet-stack-notification, events: 0x0001) at index 7
2023-03-27 15:21:03.320624 <D> <event|event.c:427> Removed generic event source (handle: 18, name: mesh-server, events: 0x0001) at index 6
2023-03-27 15:21:03.320651 <D> <event|event.c:427> Removed generic event source (handle: 17, name: server, events: 0x0001) at index 5
2023-03-27 15:21:03.320656 <D> <event|event.c:427> Removed USB event source (handle: 16, name: usb-poll, events: 0x0001) at index 4
2023-03-27 15:21:03.320662 <D> <event|event.c:427> Removed USB event source (handle: 14, name: usb-poll, events: 0x0001) at index 3
2023-03-27 15:21:03.320666 <D> <event|event.c:427> Removed generic event source (handle: 9, name: usb-hotplug, events: 0x0001) at index 2
2023-03-27 15:21:03.320670 <D> <event|event.c:427> Removed generic event source (handle: 7, name: signal, events: 0x0001) at index 1
2023-03-27 15:21:03.320674 <D> <event|event.c:427> Removed generic event source (handle: 5, name: event-stop, events: 0x0001) at index 0
2023-03-27 15:21:03.320680 <I> <main_linux.c:559> Brick Daemon 2.4.4 stopped
Ich habe SPI über die "/boot/hw_initfc.config" eingeschalten:
# Hardware Interface Config
# For more details, check https://wiki.radxa.com/Rockpi4/hardware/devtree_overlays.
# Set "on" to enable the optional hardware interfaces while set "off" to disable.
intfc:pwm0=off
intfc:pwm1=off
intfc:uart2=off
intfc:uart4=off
intfc:spi1=on
intfc:spi2=off
intfc:i2c2=off
intfc:i2c6=off
intfc:i2c7=off
# Devicetree Overlay Enable, uncomment to enable .dtbo under /boot/overlays/.
# EEPROM on I2C2
#intfc:dtoverlay=at24c02
# Serial console on UART2
intfc:dtoverlay=console-on-ttyS2
# Serial console on UART4
#intfc:dtoverlay=console-on-ttyS4
# Dummy spi device on SPI1 for test. Need set: intfc:spi1=on
intfc:dtoverlay=devspi1
darufhin wurde auch ein spi device erstellt:
root@linaro-alip:/# ls /dev/sp*
/dev/spidev32766.0
Mitlerweile erhalte ich auch nichtmehr den spi Fehler...
Meiner brickd.conf habe ich diese Zeilen angehängt:
log.level = Debug
log.debug_filter =
bricklet.group0.spidev = /dev/spidev32766.0
bricklet.group0.cs0.driver = gpio
bricklet.group0.cs0.name = gpio154 #4_D2 #P16   ### 154
bricklet.group0.cs0.num = 154
bricklet.group0.cs1.driver = gpio
bricklet.group0.cs1.name = gpio149 #4_C5 #P15   ### 149
bricklet.group0.cs1.num = 149
bricklet.group0.cs2.driver = gpio
bricklet.group0.cs2.name = gpio157 #4_D5 #P22   ### 157
bricklet.group0.cs2.num = 157
bricklet.group0.cs3.driver = gpio
bricklet.group0.cs3.name = gpio158 #4_D6 #P37   ### 158
bricklet.group0.cs3.num = 158
bricklet.group0.cs4.driver = gpio
bricklet.group0.cs4.name = gpio150 #4_C6 #P13   ### 150
bricklet.group0.cs4.num = 150
bricklet.group0.cs5.driver = gpio
bricklet.group0.cs5.name = gpio156 #4_D4 #P18   ### 156
bricklet.group0.cs5.num = 156
###these seem to bee fallback pins
bricklet.group0.cs6.driver = gpio
bricklet.group0.cs6.name = gpio7 ##P26  #ADC_IN0!?! #has no GPIO ?!??
bricklet.group0.cs6.num = 7
bricklet.group0.cs7.driver = gpio
bricklet.group0.cs7.name = gpio73 #2_B1 ##P31   ### 73
bricklet.group0.cs7.num = 73
bricklet.group0.cs8.driver = gpio
bricklet.group0.cs8.name = gpio74 #2_B2 ##P29   ### 74
Dabei habe ich versucht die GPIO Pins denen auf dem ROCK pi anzupassen. Für group0.cs6 habe ich nichts "passendes" gefunden.
Wenn ich jetzt den brickd starte, erhalte ich unter anderern diese logs:
2023-03-31 19:40:46.084804 <D> <bricklet.c:260> No HAT product_id file in device tree, not using default HAT Brick config
2023-03-31 19:40:46.084857 <D> <bricklet.c:260> No HAT product_id file in device tree, not using default HAT Zero Brick config
2023-03-31 19:40:46.084908 <D> <bricklet.c:260> No HAT product_id file in device tree, not using default HAT WARP Energy Manager Brick config
2023-03-31 19:40:46.084915 <D> <bricklet.c:465> Found no supported HAT product_id in device tree, checking bricklet.* section in config file instead
2023-03-31 19:40:46.085011 <D> <bricklet.c:546> Found no bricklet.* section in config file
Ich kann dann auch per IP mit dem brickv eine Verbindung öffenen, allerdings werden keine Geräte gefunden
image.png.e1183eb56617e0ad7932a27bbac5463a.png.
Jetzt frage ich mich, wie ich eine HAT Brick config anlegen kann, oder ob evtl etwas ganz anderes (SPI?) das Problem ist.
[EDIT]
Der vollständige Log ist:
[ 0.000010] [000005cb] libusb: debug [libusb_init] created default context
[ 0.000197] [000005cb] libusb: debug [libusb_init] libusb v1.0.21.11156
[ 0.000326] [000005cb] libusb: debug [find_usbfs_path] found usbfs at /dev/bus/usb
[ 0.000398] [000005cb] libusb: debug [op_init] bulk continuation flag supported
[ 0.000428] [000005cb] libusb: debug [op_init] zero length packet flag supported
[ 0.000494] [000005cb] libusb: debug [op_init] sysfs can relate devices
[ 0.000545] [000005cb] libusb: debug [op_init] sysfs has complete descriptors
[ 0.001239] [000005cd] libusb: debug [linux_udev_event_thread_main] udev event thread entering.
2023-03-31 19:40:46.068191 <I> <main_linux.c:369> Brick Daemon 2.4.4 started (pid: 1483, daemonized: 0)
2023-03-31 19:40:46.068233 <I> <main_linux.c:375> Running on Linux system (sysname: Linux, release: 4.4.154-90-rockchip-ga14f6502e045, version: #22 SMP Tue Jul 30 10:32:28 UTC 2019, machine: aarch64)
2023-03-31 19:40:46.068242 <D> <main_linux.c:384> Using config file: /etc/brickd.conf
2023-03-31 19:40:46.068247 <D> <main_linux.c:390> Using PID file: /var/run/brickd.pid
2023-03-31 19:40:46.068252 <W> <main_linux.c:394> Warning(s) in config file '/etc/brickd.conf', run with --check-config option for details
2023-03-31 19:40:46.068259 <D> <event.c:60> Initializing event subsystem
2023-03-31 19:40:46.068322 <D> <event|event.c:270> Added generic event source (handle: 5, name: event-stop, events: 0x0001) at index 0
2023-03-31 19:40:46.068359 <D> <event|event.c:270> Added generic event source (handle: 7, name: signal, events: 0x0001) at index 1
2023-03-31 19:40:46.068386 <D> <hardware.c:39> Initializing hardware subsystem
2023-03-31 19:40:46.068394 <D> <usb.c:296> Initializing USB subsystem
2023-03-31 19:40:46.068422 <D> <event|event.c:270> Added generic event source (handle: 9, name: usb-hotplug, events: 0x0001) at index 2
[ 0.009897] [000005cb] libusb: debug [linux_get_device_address] getting address for device: usb1 detached: 0
[ 0.010004] [000005cb] libusb: debug [linux_get_device_address] scan usb1
[ 0.010251] [000005cb] libusb: debug [linux_get_device_address] bus=1 dev=1
[ 0.010296] [000005cb] libusb: debug [linux_enumerate_device] busnum 1 devaddr 1 session_id 257
[ 0.010323] [000005cb] libusb: debug [linux_enumerate_device] allocating new device for 1/1 (session 257)
[ 0.010878] [000005cb] libusb: debug [linux_get_device_address] getting address for device: usb3 detached: 0
[ 0.010960] [000005cb] libusb: debug [linux_get_device_address] scan usb3
[ 0.011164] [000005cb] libusb: debug [linux_get_device_address] bus=3 dev=1
[ 0.011206] [000005cb] libusb: debug [linux_enumerate_device] busnum 3 devaddr 1 session_id 769
[ 0.011230] [000005cb] libusb: debug [linux_enumerate_device] allocating new device for 3/1 (session 769)
[ 0.011726] [000005cb] libusb: debug [linux_get_device_address] getting address for device: usb2 detached: 0
[ 0.011805] [000005cb] libusb: debug [linux_get_device_address] scan usb2
[ 0.012003] [000005cb] libusb: debug [linux_get_device_address] bus=2 dev=1
[ 0.012042] [000005cb] libusb: debug [linux_enumerate_device] busnum 2 devaddr 1 session_id 513
[ 0.012066] [000005cb] libusb: debug [linux_enumerate_device] allocating new device for 2/1 (session 513)
[ 0.012627] [000005cb] libusb: debug [linux_get_device_address] getting address for device: usb4 detached: 0
[ 0.012705] [000005cb] libusb: debug [linux_get_device_address] scan usb4
[ 0.012904] [000005cb] libusb: debug [linux_get_device_address] bus=4 dev=1
[ 0.012945] [000005cb] libusb: debug [linux_enumerate_device] busnum 4 devaddr 1 session_id 1025
[ 0.012968] [000005cb] libusb: debug [linux_enumerate_device] allocating new device for 4/1 (session 1025)
[ 0.013502] [000005cb] libusb: debug [linux_get_device_address] getting address for device: usb5 detached: 0
[ 0.013571] [000005cb] libusb: debug [linux_get_device_address] scan usb5
[ 0.013781] [000005cb] libusb: debug [linux_get_device_address] bus=5 dev=1
[ 0.013843] [000005cb] libusb: debug [linux_enumerate_device] busnum 5 devaddr 1 session_id 1281
[ 0.013868] [000005cb] libusb: debug [linux_enumerate_device] allocating new device for 5/1 (session 1281)
[ 0.014410] [000005cb] libusb: debug [linux_get_device_address] getting address for device: usb6 detached: 0
[ 0.014487] [000005cb] libusb: debug [linux_get_device_address] scan usb6
[ 0.014698] [000005cb] libusb: debug [linux_get_device_address] bus=6 dev=1
[ 0.014759] [000005cb] libusb: debug [linux_enumerate_device] busnum 6 devaddr 1 session_id 1537
[ 0.014783] [000005cb] libusb: debug [linux_enumerate_device] allocating new device for 6/1 (session 1537)
[ 0.015043] [000005cb] libusb: debug [usbi_add_pollfd] add fd 14 events 1
[ 0.015132] [000005cb] libusb: debug [usbi_io_init] using timerfd for timeouts
[ 0.015157] [000005cb] libusb: debug [usbi_add_pollfd] add fd 16 events 1
[ 0.015336] [000005cb] libusb: debug [libusb_get_device_list]
[ 0.015448] [000005cb] libusb: debug [libusb_get_device_descriptor]
[ 0.015484] [000005cb] libusb: debug [libusb_get_device_descriptor]
[ 0.015506] [000005cb] libusb: debug [libusb_get_device_descriptor]
2023-03-31 19:40:46.083684 <D> <event|event.c:270> Added USB event source (handle: 14, name: usb-poll, events: 0x0001) at index 3
[ 0.015527] [000005cb] libusb: debug [libusb_get_device_descriptor]
[ 0.015717] [000005cb] libusb: debug [libusb_get_device_descriptor]
[ 0.015740] [000005cb] libusb: debug [libusb_get_device_descriptor]
2023-03-31 19:40:46.083767 <D> <event|event.c:270> Added USB event source (handle: 16, name: usb-poll, events: 0x0001) at index 4
2023-03-31 19:40:46.083789 <D> <usb.c:413> Starting initial USB device scan
2023-03-31 19:40:46.083794 <D> <usb.c:492> Looking for added/removed USB devices
2023-03-31 19:40:46.083898 <D> <usb.c:186> Found 6 USB device(s)
2023-03-31 19:40:46.084273 <D> <network.c:177> Initializing network subsystem
2023-03-31 19:40:46.084304 <D> <socket.c:164> Opening server socket(s) for address '0.0.0.0' on port 4223
2023-03-31 19:40:46.084478 <D> <socket.c:264> Started listening to '0.0.0.0' (IPv4) resolved from '0.0.0.0' on port 4223
2023-03-31 19:40:46.084506 <D> <event|event.c:270> Added generic event source (handle: 17, name: server, events: 0x0001) at index 5
2023-03-31 19:40:46.084519 <D> <mesh.c:53> Initializing mesh subsystem
2023-03-31 19:40:46.084527 <D> <mesh.c:156> Mesh gateway is enabled
2023-03-31 19:40:46.084532 <D> <socket.c:164> Opening server socket(s) for address '0.0.0.0' on port 4240
[ 0.016610] [000005cb] libusb: debug [libusb_handle_events_timeout_completed] doing our own event handling
[ 0.016717] [000005cb] libusb: debug [handle_events] poll fds modified, reallocating
[ 0.016755] [000005cb] libusb: debug [handle_events] poll() 2 fds with timeout in 0ms
[ 0.016785] [000005cb] libusb: debug [handle_events] poll() returned 0
2023-03-31 19:40:46.084679 <D> <socket.c:264> Started listening to '0.0.0.0' (IPv4) resolved from '0.0.0.0' on port 4240
2023-03-31 19:40:46.084702 <D> <event|event.c:270> Added generic event source (handle: 18, name: mesh-server, events: 0x0001) at index 6
2023-03-31 19:40:46.085016 <D> <event.c:534> Starting the event loop
2023-03-31 19:40:46.085028 <D> <event|event_linux.c:147> Starting to epoll on 7 event source(s)
2023-03-31 19:40:46.085046 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:40:46.085051 <D> <event|event.c:447> Handling USB event source (handle: 14, name: usb-poll, received-events: 0x0001)
2023-03-31 19:40:46.085280 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:40:46.085288 <D> <event|event_linux.c:147> Starting to epoll on 7 event source(s)
2023-03-31 19:41:49.952954 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:41:49.953044 <D> <event|event.c:447> Handling generic event source (handle: 17, name: server, received-events: 0x0001)
2023-03-31 19:41:49.953161 <D> <client.c:393> Creating client from plain-socket (handle: 19/19)
2023-03-31 19:41:49.953199 <D> <event|event.c:270> Added generic event source (handle: 19, name: client, events: 0x0001) at index 7
2023-03-31 19:41:49.953209 <I> <network.c:304> Added new client (N: 192.168.179.127:58865, T: plain-socket, H: 19/19, B: 0, P: 0, A: disabled)
2023-03-31 19:41:49.953218 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:41:49.953226 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:41:49.972535 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:41:49.972714 <D> <event|event.c:447> Handling generic event source (handle: 19, name: client, received-events: 0x0001)
2023-03-31 19:41:49.972793 <D> <packet|client.c:335> Received request (U: 1, L: 8, F: 254, S: 10, R: 0, I: 0, packet: 00 00 00 00 08 FE A0 00) from client (N: 192.168.179.127:58865, T: plain-socket, H: 19/19, B: 8, P: 0, A: disabled)
2023-03-31 19:41:49.972820 <D> <packet|hardware.c:106> No stacks connected, dropping request (U: 1, L: 8, F: 254, S: 10, R: 0, I: 0, packet: 00 00 00 00 08 FE A0 00)
2023-03-31 19:41:49.972826 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:41:49.972836 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:41:59.969627 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:41:59.969717 <D> <event|event.c:447> Handling generic event source (handle: 19, name: client, received-events: 0x0001)
2023-03-31 19:41:59.969763 <D> <packet|client.c:325> Received disconnect probe from client (N: 192.168.179.127:58865, T: plain-socket, H: 19/19, B: 8, P: 0, A: disabled), dropping request
2023-03-31 19:41:59.969802 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:41:59.969813 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:42:04.971699 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:42:04.971789 <D> <event|event.c:447> Handling generic event source (handle: 19, name: client, received-events: 0x0001)
2023-03-31 19:42:04.971834 <D> <packet|client.c:325> Received disconnect probe from client (N: 192.168.179.127:58865, T: plain-socket, H: 19/19, B: 8, P: 0, A: disabled), dropping request
2023-03-31 19:42:04.971846 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:42:04.971857 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:42:09.974180 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:42:09.974270 <D> <event|event.c:447> Handling generic event source (handle: 19, name: client, received-events: 0x0001)
2023-03-31 19:42:09.974315 <D> <packet|client.c:325> Received disconnect probe from client (N: 192.168.179.127:58865, T: plain-socket, H: 19/19, B: 8, P: 0, A: disabled), dropping request
2023-03-31 19:42:09.974327 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:42:09.974337 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:42:14.975747 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:42:14.975836 <D> <event|event.c:447> Handling generic event source (handle: 19, name: client, received-events: 0x0001)
2023-03-31 19:42:14.975880 <D> <packet|client.c:325> Received disconnect probe from client (N: 192.168.179.127:58865, T: plain-socket, H: 19/19, B: 8, P: 0, A: disabled), dropping request
2023-03-31 19:42:14.975892 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:42:14.975903 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:42:19.977223 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:42:19.977314 <D> <event|event.c:447> Handling generic event source (handle: 19, name: client, received-events: 0x0001)
2023-03-31 19:42:19.977358 <D> <packet|client.c:325> Received disconnect probe from client (N: 192.168.179.127:58865, T: plain-socket, H: 19/19, B: 8, P: 0, A: disabled), dropping request
2023-03-31 19:42:19.977370 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:42:19.977381 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:42:24.978410 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:42:24.978499 <D> <event|event.c:447> Handling generic event source (handle: 19, name: client, received-events: 0x0001)
2023-03-31 19:42:24.978549 <D> <packet|client.c:325> Received disconnect probe from client (N: 192.168.179.127:58865, T: plain-socket, H: 19/19, B: 8, P: 0, A: disabled), dropping request
2023-03-31 19:42:24.978561 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:42:24.978572 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:42:29.979440 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:42:29.979531 <D> <event|event.c:447> Handling generic event source (handle: 19, name: client, received-events: 0x0001)
2023-03-31 19:42:29.979576 <D> <packet|client.c:325> Received disconnect probe from client (N: 192.168.179.127:58865, T: plain-socket, H: 19/19, B: 8, P: 0, A: disabled), dropping request
2023-03-31 19:42:29.979588 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:42:29.979599 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:42:33.730367 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:42:33.730487 <D> <event|event.c:447> Handling generic event source (handle: 19, name: client, received-events: 0x0001)
2023-03-31 19:42:33.730526 <I> <client.c:263> Client (N: 192.168.179.127:58865, T: plain-socket, H: 19/19, B: 0, P: 0, A: disabled) disconnected by peer
2023-03-31 19:42:33.730537 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:42:33.730543 <D> <network.c:346> Removing disconnected client (N: 192.168.179.127:58865, T: plain-socket, H: 19/19, B: 0, P: 0, A: disabled)
2023-03-31 19:42:33.730568 <D> <event|event.c:408> Marked generic event source (handle: 19, name: client, events: 0x0001) as removed at index 7
2023-03-31 19:42:33.730724 <D> <event|event.c:427> Removed generic event source (handle: 19, name: client, events: 0x0001) at index 7
2023-03-31 19:42:33.730740 <D> <event|event_linux.c:147> Starting to epoll on 7 event source(s)
2023-03-31 19:45:04.510430 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:45:04.510521 <D> <event|event.c:447> Handling generic event source (handle: 17, name: server, received-events: 0x0001)
2023-03-31 19:45:04.510617 <D> <client.c:393> Creating client from plain-socket (handle: 19/19)
2023-03-31 19:45:04.510645 <D> <event|event.c:270> Added generic event source (handle: 19, name: client, events: 0x0001) at index 7
2023-03-31 19:45:04.510655 <I> <network.c:304> Added new client (N: 192.168.179.127:58977, T: plain-socket, H: 19/19, B: 0, P: 0, A: disabled)
2023-03-31 19:45:04.510665 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:45:04.510673 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:45:04.523302 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:45:04.523393 <D> <event|event.c:447> Handling generic event source (handle: 19, name: client, received-events: 0x0001)
2023-03-31 19:45:04.523458 <D> <packet|client.c:335> Received request (U: 1, L: 8, F: 254, S: 12, R: 0, I: 0, packet: 00 00 00 00 08 FE C0 00) from client (N: 192.168.179.127:58977, T: plain-socket, H: 19/19, B: 8, P: 0, A: disabled)
2023-03-31 19:45:04.523485 <D> <packet|hardware.c:106> No stacks connected, dropping request (U: 1, L: 8, F: 254, S: 12, R: 0, I: 0, packet: 00 00 00 00 08 FE C0 00)
2023-03-31 19:45:04.523491 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:45:04.523500 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:45:14.510314 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:45:14.510404 <D> <event|event.c:447> Handling generic event source (handle: 19, name: client, received-events: 0x0001)
2023-03-31 19:45:14.510447 <D> <packet|client.c:325> Received disconnect probe from client (N: 192.168.179.127:58977, T: plain-socket, H: 19/19, B: 8, P: 0, A: disabled), dropping request
2023-03-31 19:45:14.510459 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:45:14.510469 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:45:19.510768 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:45:19.510860 <D> <event|event.c:447> Handling generic event source (handle: 19, name: client, received-events: 0x0001)
2023-03-31 19:45:19.510905 <D> <packet|client.c:325> Received disconnect probe from client (N: 192.168.179.127:58977, T: plain-socket, H: 19/19, B: 8, P: 0, A: disabled), dropping request
2023-03-31 19:45:19.510917 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:45:19.510928 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:45:24.512936 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:45:24.513026 <D> <event|event.c:447> Handling generic event source (handle: 19, name: client, received-events: 0x0001)
2023-03-31 19:45:24.513072 <D> <packet|client.c:325> Received disconnect probe from client (N: 192.168.179.127:58977, T: plain-socket, H: 19/19, B: 8, P: 0, A: disabled), dropping request
2023-03-31 19:45:24.513110 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:45:24.513121 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:45:29.513831 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:45:29.513922 <D> <event|event.c:447> Handling generic event source (handle: 19, name: client, received-events: 0x0001)
2023-03-31 19:45:29.513966 <D> <packet|client.c:325> Received disconnect probe from client (N: 192.168.179.127:58977, T: plain-socket, H: 19/19, B: 8, P: 0, A: disabled), dropping request
2023-03-31 19:45:29.513978 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:45:29.513989 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:45:34.514631 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:45:34.514721 <D> <event|event.c:447> Handling generic event source (handle: 19, name: client, received-events: 0x0001)
2023-03-31 19:45:34.514763 <D> <packet|client.c:325> Received disconnect probe from client (N: 192.168.179.127:58977, T: plain-socket, H: 19/19, B: 8, P: 0, A: disabled), dropping request
2023-03-31 19:45:34.514775 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:45:34.514785 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:45:39.515342 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:45:39.515433 <D> <event|event.c:447> Handling generic event source (handle: 19, name: client, received-events: 0x0001)
2023-03-31 19:45:39.515478 <D> <packet|client.c:325> Received disconnect probe from client (N: 192.168.179.127:58977, T: plain-socket, H: 19/19, B: 8, P: 0, A: disabled), dropping request
2023-03-31 19:45:39.515489 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:45:39.515500 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:45:44.516291 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:45:44.516381 <D> <event|event.c:447> Handling generic event source (handle: 19, name: client, received-events: 0x0001)
2023-03-31 19:45:44.516426 <D> <packet|client.c:325> Received disconnect probe from client (N: 192.168.179.127:58977, T: plain-socket, H: 19/19, B: 8, P: 0, A: disabled), dropping request
2023-03-31 19:45:44.516438 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:45:44.516448 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:45:49.517225 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:45:49.517315 <D> <event|event.c:447> Handling generic event source (handle: 19, name: client, received-events: 0x0001)
2023-03-31 19:45:49.517359 <D> <packet|client.c:325> Received disconnect probe from client (N: 192.168.179.127:58977, T: plain-socket, H: 19/19, B: 8, P: 0, A: disabled), dropping request
2023-03-31 19:45:49.517371 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:45:49.517382 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:45:54.518484 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:45:54.518575 <D> <event|event.c:447> Handling generic event source (handle: 19, name: client, received-events: 0x0001)
2023-03-31 19:45:54.518619 <D> <packet|client.c:325> Received disconnect probe from client (N: 192.168.179.127:58977, T: plain-socket, H: 19/19, B: 8, P: 0, A: disabled), dropping request
2023-03-31 19:45:54.518631 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:45:54.518642 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:45:59.519544 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:45:59.519633 <D> <event|event.c:447> Handling generic event source (handle: 19, name: client, received-events: 0x0001)
2023-03-31 19:45:59.519703 <D> <packet|client.c:325> Received disconnect probe from client (N: 192.168.179.127:58977, T: plain-socket, H: 19/19, B: 8, P: 0, A: disabled), dropping request
2023-03-31 19:45:59.519715 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:45:59.519725 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:46:04.520988 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:46:04.521072 <D> <event|event.c:447> Handling generic event source (handle: 19, name: client, received-events: 0x0001)
2023-03-31 19:46:04.521118 <D> <packet|client.c:325> Received disconnect probe from client (N: 192.168.179.127:58977, T: plain-socket, H: 19/19, B: 8, P: 0, A: disabled), dropping request
2023-03-31 19:46:04.521130 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:46:04.521141 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:46:09.521620 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:46:09.521710 <D> <event|event.c:447> Handling generic event source (handle: 19, name: client, received-events: 0x0001)
2023-03-31 19:46:09.521754 <D> <packet|client.c:325> Received disconnect probe from client (N: 192.168.179.127:58977, T: plain-socket, H: 19/19, B: 8, P: 0, A: disabled), dropping request
2023-03-31 19:46:09.521766 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:46:09.521776 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:46:14.522581 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:46:14.522671 <D> <event|event.c:447> Handling generic event source (handle: 19, name: client, received-events: 0x0001)
2023-03-31 19:46:14.522716 <D> <packet|client.c:325> Received disconnect probe from client (N: 192.168.179.127:58977, T: plain-socket, H: 19/19, B: 8, P: 0, A: disabled), dropping request
2023-03-31 19:46:14.522728 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:46:14.522738 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:46:19.523086 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:46:19.523175 <D> <event|event.c:447> Handling generic event source (handle: 19, name: client, received-events: 0x0001)
2023-03-31 19:46:19.523220 <D> <packet|client.c:325> Received disconnect probe from client (N: 192.168.179.127:58977, T: plain-socket, H: 19/19, B: 8, P: 0, A: disabled), dropping request
2023-03-31 19:46:19.523232 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:46:19.523242 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:46:24.523699 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:46:24.523773 <D> <event|event.c:447> Handling generic event source (handle: 19, name: client, received-events: 0x0001)
2023-03-31 19:46:24.523816 <D> <packet|client.c:325> Received disconnect probe from client (N: 192.168.179.127:58977, T: plain-socket, H: 19/19, B: 8, P: 0, A: disabled), dropping request
2023-03-31 19:46:24.523828 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:46:24.523838 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:46:29.524381 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:46:29.524470 <D> <event|event.c:447> Handling generic event source (handle: 19, name: client, received-events: 0x0001)
2023-03-31 19:46:29.524521 <D> <packet|client.c:325> Received disconnect probe from client (N: 192.168.179.127:58977, T: plain-socket, H: 19/19, B: 8, P: 0, A: disabled), dropping request
2023-03-31 19:46:29.524533 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:46:29.524544 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
^C2023-03-31 19:46:31.565530 <D> <event_linux.c:154> EPoll got interrupted
2023-03-31 19:46:31.565604 <D> <event|event_linux.c:147> Starting to epoll on 8 event source(s)
2023-03-31 19:46:31.565622 <D> <event|event_linux.c:166> EPoll returned 1 event source(s) as ready
2023-03-31 19:46:31.565628 <D> <event|event.c:447> Handling generic event source (handle: 7, name: signal, received-events: 0x0001)
2023-03-31 19:46:31.565666 <I> <signal.c:51> Received SIGINT
2023-03-31 19:46:31.565682 <D> <event.c:568> Stopping the event loop
2023-03-31 19:46:31.565686 <D> <event|event_linux.c:179> Handled all ready event sources
2023-03-31 19:46:31.565700 <D> <event.c:541> Event loop stopped
2023-03-31 19:46:31.565713 <D> <mesh.c:74> Shutting down mesh subsystem
2023-03-31 19:46:31.565731 <D> <event|event.c:408> Marked generic event source (handle: 18, name: mesh-server, events: 0x0001) as removed at index 6
[345.498260] [000005cb] libusb: debug [libusb_exit]
[345.498385] [000005cb] libusb: debug [libusb_exit] destroying default context
[345.498441] [000005cb] libusb: debug [libusb_handle_events_timeout_completed] doing our own event handling
[345.498467] [000005cb] libusb: debug [handle_events] poll() 2 fds with timeout in 0ms
[345.498512] [000005cb] libusb: debug [handle_events] poll() returned 1
[345.498546] [000005cb] libusb: debug [handle_events] caught a fish on the event pipe
[345.498630] [000005cb] libusb: debug [handle_events] hotplug message received
[345.498677] [000005cb] libusb: debug [handle_events] poll() 2 fds with timeout in 0ms
[345.498703] [000005cb] libusb: debug [handle_events] poll() returned 1
[345.498723] [000005cb] libusb: debug [handle_events] caught a fish on the event pipe
[345.498742] [000005cb] libusb: debug [handle_events] hotplug message received
[345.498773] [000005cb] libusb: debug [handle_events] poll() 2 fds with timeout in 0ms
2023-03-31 19:46:31.566454 <D> <network.c:275> Shutting down network subsystem
[345.498798] [000005cb] libusb: debug [handle_events] poll() returned 0
[345.499146] [000005cb] libusb: debug [libusb_unref_device] destroy device 6.1
2023-03-31 19:46:31.566482 <D> <event|event.c:408> Marked generic event source (handle: 17, name: server, events: 0x0001) as removed at index 5
2023-03-31 19:46:31.566535 <D> <event|event.c:408> Marked generic event source (handle: 19, name: client, events: 0x0001) as removed at index 7
2023-03-31 19:46:31.566639 <D> <usb.c:451> Shutting down USB subsystem
2023-03-31 19:46:31.566662 <D> <event|event.c:408> Marked USB event source (handle: 14, name: usb-poll, events: 0x0001) as removed at index 3
[345.499224] [000005cb] libusb: debug [libusb_unref_device] destroy device 5.1
2023-03-31 19:46:31.566679 <D> <event|event.c:408> Marked USB event source (handle: 16, name: usb-poll, events: 0x0001) as removed at index 4
[345.499596] [000005cb] libusb: debug [libusb_unref_device] destroy device 4.1
[345.499638] [000005cb] libusb: debug [libusb_unref_device] destroy device 2.1
[345.499672] [000005cb] libusb: debug [libusb_unref_device] destroy device 3.1
[345.499705] [000005cb] libusb: debug [libusb_unref_device] destroy device 1.1
[345.499738] [000005cb] libusb: debug [usbi_remove_pollfd] remove fd 14
[345.499853] [000005cb] libusb: debug [usbi_remove_pollfd] remove fd 16
[345.500024] [000005cd] libusb: debug [linux_udev_event_thread_main] udev event thread exiting
2023-03-31 19:46:31.568980 <D> <event|event.c:408> Marked generic event source (handle: 9, name: usb-hotplug, events: 0x0001) as removed at index 2
2023-03-31 19:46:31.569124 <D> <hardware.c:53> Shutting down hardware subsystem
2023-03-31 19:46:31.569157 <D> <event|event.c:408> Marked generic event source (handle: 7, name: signal, events: 0x0001) as removed at index 1
2023-03-31 19:46:31.569201 <D> <event.c:124> Shutting down event subsystem
2023-03-31 19:46:31.569215 <D> <event|event.c:408> Marked generic event source (handle: 5, name: event-stop, events: 0x0001) as removed at index 0
2023-03-31 19:46:31.569268 <D> <event|event.c:427> Removed generic event source (handle: 19, name: client, events: 0x0001) at index 7
2023-03-31 19:46:31.569281 <D> <event|event.c:427> Removed generic event source (handle: 18, name: mesh-server, events: 0x0001) at index 6
2023-03-31 19:46:31.569292 <D> <event|event.c:427> Removed generic event source (handle: 17, name: server, events: 0x0001) at index 5
2023-03-31 19:46:31.569302 <D> <event|event.c:427> Removed USB event source (handle: 16, name: usb-poll, events: 0x0001) at index 4
2023-03-31 19:46:31.569312 <D> <event|event.c:427> Removed USB event source (handle: 14, name: usb-poll, events: 0x0001) at index 3
2023-03-31 19:46:31.569322 <D> <event|event.c:427> Removed generic event source (handle: 9, name: usb-hotplug, events: 0x0001) at index 2
2023-03-31 19:46:31.569332 <D> <event|event.c:427> Removed generic event source (handle: 7, name: signal, events: 0x0001) at index 1
2023-03-31 19:46:31.569342 <D> <event|event.c:427> Removed generic event source (handle: 5, name: event-stop, events: 0x0001) at index 0
2023-03-31 19:46:31.569353 <I> <main_linux.c:559> Brick Daemon 2.4.4 stopped
root@linaro-alip:/#
bearbeitet von FATTOMCAT
Du bekommst den spidev Fehler nicht mehr, weil brickd jetzt gar nicht mehr soweit kommt.
brickd versteht die /etc/brckd.conf Datei nicht mehr.
Führe bitte diesen Befehl in eine Terminal aus und poste die Ausgabe hier.
sudo brickd --check-config
sudo brickd --check-config liefert:
Line 80 contains non-printable ASCII character: 0x09
Line 84 contains non-printable ASCII character: 0x09
Line 88 contains non-printable ASCII character: 0x09
Line 92 contains non-printable ASCII character: 0x09
Line 96 contains non-printable ASCII character: 0x09
Line 100 contains non-printable ASCII character: 0x09
Line 106 contains non-printable ASCII character: 0x09
Line 110 contains non-printable ASCII character: 0x09
Line 114 contains non-printable ASCII character: 0x09
Using the following config values:
  listen.address                       = 0.0.0.0
  listen.plain_port                    = 4223
  listen.websocket_port                = 0
  listen.mesh_gateway_port             = 4240
  listen.dual_stack                    = off
  authentication.secret                =
  log.level                            = debug
  log.debug_filter                     =
  bricklet.portA.sleep_between_reads   = 200
  bricklet.portB.sleep_between_reads   = 200
  bricklet.portC.sleep_between_reads   = 200
  bricklet.portD.sleep_between_reads   = 200
  bricklet.portE.sleep_between_reads   = 200
  bricklet.portF.sleep_between_reads   = 200
  bricklet.portG.sleep_between_reads   = 200
  bricklet.portH.sleep_between_reads   = 200
  bricklet.portI.sleep_between_reads   = 200
  bricklet.portJ.sleep_between_reads   = 200
  bricklet.portHAT.sleep_between_reads = 2000
  bricklet.spi.driver                  = auto
  bricklet.group1.spidev               =
  bricklet.group0.cs9.driver           = <unknown>
  bricklet.group1.cs0.driver           = <unknown>
  bricklet.group1.cs1.driver           = <unknown>
  bricklet.group1.cs2.driver           = <unknown>
  bricklet.group1.cs3.driver           = <unknown>
  bricklet.group1.cs4.driver           = <unknown>
  bricklet.group1.cs5.driver           = <unknown>
  bricklet.group1.cs6.driver           = <unknown>
  bricklet.group1.cs7.driver           = <unknown>
  bricklet.group1.cs8.driver           = <unknown>
  bricklet.group1.cs9.driver           = <unknown>
  bricklet.group0.cs8.num              = 74
  bricklet.group0.cs9.num              = -1
  bricklet.group1.cs0.num              = -1
  bricklet.group1.cs1.num              = -1
  bricklet.group1.cs2.num              = -1
  bricklet.group1.cs3.num              = -1
  bricklet.group1.cs4.num              = -1
  bricklet.group1.cs5.num              = -1
  bricklet.group1.cs6.num              = -1
  bricklet.group1.cs7.num              = -1
  bricklet.group1.cs8.num              = -1
  bricklet.group1.cs9.num              = -1
  bricklet.group0.cs9.name             =
  bricklet.group1.cs0.name             =
  bricklet.group1.cs1.name             =
  bricklet.group1.cs2.name             =
  bricklet.group1.cs3.name             =
  bricklet.group1.cs4.name             =
  bricklet.group1.cs5.name             =
  bricklet.group1.cs6.name             =
  bricklet.group1.cs7.name             =
  bricklet.group1.cs8.name             =
  bricklet.group1.cs9.name             =
Ich hab daraufhin die tabs aus den Kommentaren entfernt und in die nächste Zeile verschoben:
No warnings or errors in config file '/etc/brickd.conf'
  log.level                            = debug
  log.debug_filter                     =
Jetzt erhalte ich wieder den Fehler vom Anfang.
Der Kernel meldet EINVAL (ungültiges Argument) für den Versuch den SPI Modus auf SPI_MODE_3|SPI_NO_CS zu konfigurieren.
Ich habe in den Kernel Source Code geschaut und vermute, dass das Rock Pi 4 den SPI_NO_CS Modus nicht unterstüzt.
https://elixir.bootlin.com/linux/v5.10/source/drivers/spi/spi.c#L3342
https://elixir.bootlin.com/linux/v5.10/source/drivers/spi/spi-rockchip.c#L725
https://elixir.bootlin.com/linux/v5.10/source/drivers/spi/spi-bcm2835.c#L1289
Teste mal bitte die angehängt brickd Version. Die versucht jetzt nicht mehr SPI_NO_CS zu setzen. Dadurch bewegt die SPI Hardware-Einheit dann unnötigerweise den Chip-Select-Pin, was aber hoffentlich ins Leere läuft.
brickd_2.4.4+snapshot~889c425_arm64.deb
