frohes neues jahr, tinkers!
habe eben mein brickv von 1.1.13 auf 1.1.18 (vom 27.12. letzten jahres) upgraded - mit dem resultat, dass Brickv nicht mehr läuft.
Soweit ich weiss ist das Framework CoreText erst ab 10.8 (Mountain Lion) in /System/Library/Frameworks/ verfügbar. Das Problem mit den scripting additions verstehe ich nicht, da ich ich nie Python verwendet habe.
Hier die relevanten 'consolations':
02/01/2013 16:43:49 [0x0-0x25025].com.tinkerforge.brickv[333] Traceback (most recent call last):
02/01/2013 16:43:49 [0x0-0x25025].com.tinkerforge.brickv[333]   File "/Applications/Brickv.app/Contents/Resources/__boot__.py", line 340, in <module>
02/01/2013 16:43:49 [0x0-0x25025].com.tinkerforge.brickv[333]     _run('main.py')
02/01/2013 16:43:49 [0x0-0x25025].com.tinkerforge.brickv[333]   File "/Applications/Brickv.app/Contents/Resources/__boot__.py", line 337, in _run
02/01/2013 16:43:49 [0x0-0x25025].com.tinkerforge.brickv[333]     execfile(path, globals(), globals())
02/01/2013 16:43:49 [0x0-0x25025].com.tinkerforge.brickv[333]   File "/Applications/Brickv.app/Contents/Resources/main.py", line 37, in <module>
02/01/2013 16:43:49 [0x0-0x25025].com.tinkerforge.brickv[333]     from PyQt4.QtGui import QApplication
02/01/2013 16:43:49 [0x0-0x25025].com.tinkerforge.brickv[333]   File "PyQt4/QtGui.pyc", line 18, in <module>
02/01/2013 16:43:49 [0x0-0x25025].com.tinkerforge.brickv[333]   File "PyQt4/QtGui.pyc", line 11, in __load
02/01/2013 16:43:49 [0x0-0x25025].com.tinkerforge.brickv[333] ImportError: dlopen(/Applications/Brickv.app/Contents/Resources/lib/python2.6/lib-dynload/PyQt4/QtGui.so, 2): Library not loaded: /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
02/01/2013 16:43:49 [0x0-0x25025].com.tinkerforge.brickv[333]   Referenced from: /Applications/Brickv.app/Contents/MacOS/../Frameworks/libQtGui.4.dylib
02/01/2013 16:43:49 [0x0-0x25025].com.tinkerforge.brickv[333]   Reason: image not found
02/01/2013 16:43:49 main[333] Brickv Error
02/01/2013 16:43:51 osascript[345] Error loading /Library/ScriptingAdditions/QXPScriptingAdditions.osax/Contents/MacOS/QXPScriptingAdditions:  dlopen(/Library/ScriptingAdditions/QXPScriptingAdditions.osax/Contents/MacOS/QXPScriptingAdditions, 262): no suitable image found.  Did find:
/Library/ScriptingAdditions/QXPScriptingAdditions.osax/Contents/MacOS/QXPScriptingAdditions: mach-o, but wrong architecture
02/01/2013 16:44:00 com.apple.launchd.peruser.501[242] ([0x0-0x25025].com.tinkerforge.brickv[333]) Exited with exit code: 255
Werde nun zu 1.1.13 reverten -- habt ihr ein paar schnelle tipps, was ich sonst machen sollte? Was ist die minimale OS version für Brickv? Habe nix auf der download page gefunden (aber ehrlichgesagt auch nicht lange gesucht).
-ch
Äh, ja wir haben da etwas Ärger mit der MacPorts Installation auf unserem MacBook und da ist wohl eine zu neu Qt Library eingerutscht. Du könntest mal Brick Viewer 1.1.16 testen, diese Version sollte nicht betroffen sein. Bei 1.1.17 bin ich mir nicht sicher.
ich habe den Brickv 1.1.16 auf meinem MacBook Pro (10.8.2) und da gehen nur die Graphen vom Temperatur- und Luftfeuchtigkeitsbricklet nicht.
Traue mich jetzt nicht den neuen zu laden. :(
Hoffe ich konnte helfen.
Viele Grüße,
Nemo
@Nemo: 1.1.18 sollte auf einem 10.8.2 Macbook funktionieren. Soweit ich das sehe gibt es nur Probleme bei OS X < 10.8, da es dort noch kein CoreText gab.
Wir werden aber noch ein 1.1.19 releasen das wieder kein CoreText benötigt.
@boscha: What version of Brick Viewer did crash for you?
