Meine Frage:Wie soll ich Phyton sagen, dass es sich mit dem Brick verbinden soll?
Wie verbindet sich Phyton mit den Bricks? Wenn ich direkt den Quellcode eingebe sagt es, es könne nicht das angegebene Modul finden.
Quelltext:
HOST = "localhost"
PORT = 4223
UID = "XYZ" # Change to your UID
from tinkerforge.bricklet_distance_ir import DistanceIR
# Callback function for distance callback (parameter has unit mm)
def cb_distance(distance):
    print('Distance: ' + str(distance/10.0) + ' cm')
if __name__ == "__main__":
    ipcon = IPConnection(HOST, PORT) # Create IP connection to brickd
    dist = DistanceIR(UID) # Create device object
    ipcon.add_device(dist) # Add device to IP connection
    # Don't use device before it is added to a connection
    # Set Period for distance callback to 0.2s (200ms)
    # Note: The callback is only called every 200ms if the
    #       distance has changed since the last call!
    dist.set_distance_callback_period(200)
    # Register distance callback to function cb_distance
    dist.register_callback(dist.CALLBACK_DISTANCE, cb_distance)
    raw_input('Press key to exit\n') # Use input() in Python 3
    ipcon.destroy()
