neomutant Geschrieben December 11, 2012 at 11:54 Geschrieben December 11, 2012 at 11:54 Hi What I am doing wrong? I have a ServoBrick +MasterBrick +JoystickBricklet +WiFiExt on RcHeli and im trying to control 3 servos on Heli. When i use usb connection is ok = read the joystick position and sets the servos position in real time. When I do it over Wi-Fi servo change their position at about ~ 400-500ms instead of every ~ 2ms (usb). I was expecting a lag in the transmission of the WI-Fi, but not like this. 1) What is the delay in your projects? 2) How can I reduce the delay? Zitieren
batti Geschrieben December 11, 2012 at 12:36 Geschrieben December 11, 2012 at 12:36 Hi, we wouldn't expect a lag like this, too. It's hard to say what the reason for this can be. Can you attach your code? Thanks, Bastian Zitieren
neomutant Geschrieben December 11, 2012 at 12:51 Autor Geschrieben December 11, 2012 at 12:51 I Will simplify the code and measure the exact lag. IF will still be as high, i will post the the code and exe. Zitieren
