neomutant Geschrieben December 5, 2012 at 00:37 Geschrieben December 5, 2012 at 00:37 Hi Just like in subject. Kris. Zitieren
batti Geschrieben December 5, 2012 at 15:29 Geschrieben December 5, 2012 at 15:29 Dear Kris, we have not tested the range. It's not easy to give general information about it, since it depends on many things. Evidently, the range is outdoor greater then indoors with walls in between. Big reinforced concrete walls will effect it more than slim dry walls. Our Wifi module has an power amplifier with 18dBm output power. That's a lot if you compare it with other modules. So you can expect a higher range than with other typical wifi products. Sorry that I can't give you more information at the moment. Bastian Zitieren
neomutant Geschrieben December 5, 2012 at 16:00 Autor Geschrieben December 5, 2012 at 16:00 Wanted to know is it in between (outdoor, small antennas): - (10-20m); - (20-50m); - (50-150m); - or to 500m so i have to test it out. Im planing to use it on RC helicopter with very expensive payload. I have to know how much I can fly away. I will have fail-safes for return home in case of loosing signal. For sure I will test it on the ground fist, and share with test results. Zitieren
batti Geschrieben December 6, 2012 at 08:29 Geschrieben December 6, 2012 at 08:29 Dear Kris, I would expect a range of > 500m outdoors in case that you use a suitable counterpart. Your project seems to be very interesting. Please share it with us. Zitieren
neomutant Geschrieben December 6, 2012 at 09:39 Autor Geschrieben December 6, 2012 at 09:39 It will be a big RC Helicopter Drone for filming from the air. Autonomous, but controlled from the ground. Will fly along the designated 3D points (sent from the computer during the flight or manually marked during the flight manual). Similarly gimbal control (Camera control and stabilization system) that will switch between modes (GpsTracking point3D tracking, HeadTraking with video feed, manual / stick). It will operate under local control (on helicopter, with the help of sensors) system preventing collisions in the case when the flight route will be on a collision course. GPS precision and speed will be increased using an accelerometer, and a mini camera horizontally stabilized always directed vertically downward. Zitieren
batti Geschrieben December 6, 2012 at 12:05 Geschrieben December 6, 2012 at 12:05 Sounds great! Please keep us posted. Zitieren
neomutant Geschrieben December 6, 2012 at 20:10 Autor Geschrieben December 6, 2012 at 20:10 The base is this Heli Trex 700e v2 (just the version flybarless v2 and not flybar like in the movie) this heli is great for 3D acrobatic and it's lifting capabilities is outstanding. Zitieren
